Well, after some hard drive issues in my Dell laptop earlier this year (a slow but certain HD death), I decided to try out an SSD drive. I'm not as computer-savvy as I used to be, so I had a local computer shop source a relatively less-common EIDE SSD for my older Dell, as well as install & configure it (I undertook the WinXP reinstall).
The cost was $190 for a 64GB Super Talent EIDE (MLC), ~110 MB/sec transfer rate IIRC. I might have been able to find something cheaper and/or faster but I'd rather have the local shop take responsibility for the upgrade & making sure everything is functional - fewer folks able to point their finger at others if something isn't working, you know how that goes ...
So I'm pretty happy with it so far, a low-level format took ~30 seconds, and WinXP boots up in something like half the time as previously.
The other thing I've just accomplished with this laptop is that I picked up a Lexar 32-bit CardBus PCMCIA -> Compact Flash adaptor, as I've always wanted significant secondary flash drive capacity that is completely internal to my laptop. Furthermore, it's nice to use the commodity-type cards such as CF & SD - with so many companies competing, it's easier to get high-performance upgrades at a lower cost. Now when I need more capacity in my 'second hard drive', I can just pop out the CF card and insert one with greater capacity as the costs come down.
The other advantage that I see with this strategy is that since MLC flash memory is only good for ~3000 write cycles (albeit not as significant an issue with wear leveling algorithms), I can 'offload' a lot of the more-intensive read-write use (such as the My Documents & Settings folder, Temporary Internet Files, and virtual memory/swap) to the CF drive, saving my expensive & harder to replace internal SSD HD for the OS and various applications.
And it is still fast enough, a 32GB low-level format of this card took only 20 seconds, and since the 32-bit (CardBus) bus is most definitely not the data bottleneck in this configuration, I'm only limited by the quite-respectable ~60MB/sec transfer rate of this particular line of Sandisk CF cards.
BTW, do any of the computer gurus here know of a way to turn off last-fileaccess-time stamping with removable media using WinXP & Fat32? I'm tempted to convert the CF card from Fat32 to NTFS and/or make it a 'fixed' volume to facilitate this, but I'm wondering if there is a more straightforward approach ... ?I also want to enable write-cacheing for this drive, so I'm inclined to make it a fixed volume...
So anyway, I'd be curious as to who here has been using SSD's in place of traditional hard disks for their computers, and what experiences they've had? It sounds like there were a lot of failures in the first ones to come out, but I'm hoping that the more recent SSD's have been more reliable ...
Your thoughts?
