Hi Vinhnguyen54, I would like to get in on your new years give away, So i will be ordering somethimg tonight, I just have a few questions to help me decide which setup I will get.
1.) Personally I would like to get something along the lines of Low voltage (4.2v max) multi-mode in a T6 or U2 with DD, Med, Strobe, but I dont think that is an option anymore, right?
2.) If not an option I want to get either your 4.2v max 1 mode DD option or your Multi-Mode Low Voltage 2.7v - 4.5v High Current option driven somewhere around 4.2a - 4.4a. The only concern with the later of these two is, will I get the maxium output seeing as 4.5 volt wouldnt be reacheable with the battery i would be using (AW3100). Every time I charge it it tops off at 4.17 - 4.20.
4.) If I wont get ultimate output without the 4.5 volts would increasing the amps help get more lumens out of it?
5.) Also, I would like to be able to use the pill itself in my Dereelight DBS or a P-60 forum factor.
Thanks.
