- Joined
- Jul 15, 2007
- Messages
- 591
I'm trying to find an efficient ballast for overdriving- the one that appears to be the best selection, lowest power consumption, is the GE UltraMax H 71723 - has a ballast factor of 1.18.
There is also a 6 tube version; unfortunately tis 80$, almost the cost of the fixture I was putting them in.
When you overdrive a bulb you 'double up' two of the output leads to each tube. This increases the brightness at the cost of lifetime.
Some of the lower ballasts have BFs of .77- they're advertised as energy saving.
Suggestions?
Suggestions?
