The Fenix-Store
Page 27 of 27 FirstFirst ... 172021222324252627
Results 781 to 800 of 800
Thread: Foursevens Preon P0
  1. #781
    Flashaholic Danielight's Avatar
    Dec 2011
    OH
    Question Re: Foursevens Preon P0
    So if I decide to order a Preon P0 now, I can be pretty sure I'll get the "new & improved" version 2, right?
    ὁ θεὸς φῶς ἐστιν
  2. #782
    Mar 2007
    Lake Como, Italy
    Default Re: Foursevens Preon P0
    Quote Originally Posted by Danielight View Post
    I you order it directly from 4Sevens the answer is yes. In case of a dealer you can not be 100% sure, they might have some old ones laying around.
  3. #783
    Dec 2011
    OH
    Quote Originally Posted by Kilovolt View Post
    Looks like Going Gear has the P0 for a pretty good price and reasonable shipping. If I ask them about the version they are currently shipping, they should know whether it's the newest. Anyone here ordered this light from Going Gear?
    ὁ θεὸς φῶς ἐστιν
  4. #784
    Flashaholic Streamer's Avatar
    Feb 2007
    Behind The Lamp
    Maybe they'll be nice enough to take a look inside the P0 head for you. The most obvious upgrade to version II will be the red rubber washer in the head as pictured below. Version 1 had the black softer foam type washer.
  5. #785
    Aug 2008
    Vancouver, BC
    I just got my new P0 back from 4sevens. I sent in my old one after it got really hot on eneloops. They sent me a new one that works perfectly with eneloops. Thanks 4sevens you are awesome.
    4Sevens Quark AA^2 Ti, ReVo SS, Zebralight H51W, Fenix TK35, itp A3 EOS, Fenix E21 L2D, E01, TK20, LD01 SS, E01; MAG 2D w terralux drop in; AKOray k-106
  6. #786
    Flashaholic* Got Lumens?'s Avatar
    Mar 2011
    Champlain Valley
    Another easier way rather than having the dealer open the product, is to ask when the stock was ordered. All the first run stock was sold prior to ~April 2012. So if they recieved the lights from Four Sevens after ~March 2012, chances are they are the new version 2.
    I have spoken to a couple of dealers that know which version they have and are selling, it doesn't hurt to ask which version they are selling if you are not ordering direct.
    I have ordered from Going Gear before, they are a good dealer and answer questions like this with ease.
    GL
    Neutrālisflashaholic
  7. #787
    Flashaholic* Haesslich's Avatar
    Nov 2003
    Mountain Equipment Co-Op has the P0 in stock now - I was in Victoria last Friday, and just got one from another store in AB today. It's V2 for sure - deeper threading on the body. This beats out my Preon 1, Quark Mini 123 and CR2 in usability thanks to the Moonlight mode, which was the best part of the AA2 (now renamed), and the size is perfect for easy pocket carry.
    And it's cheap enouhh to be given away to anyone who needs a pocket or purse light. . I'm very pleased with the revised version. It's not a perfect light, nor a powerful one... but it's got a usable flood and low-low setting. I can match this up with my Preon 2 HiCRI and take care of 80% of my daily flashlight needs. For anything that needs 100-200+ lumens I can handle with my LD40 or TK35 (one of which always travels with me).
  8. #788
    Flashaholic* gunga's Avatar
    Nov 2006
    Vancouver, BC, Canada
    Default
    I got one yesterday. Tiny, and cool.
  9. #789
  10. #790
    Nov 2006
    Yep. I decided I wanted one, didn't want to wait 10 days to 2 weeks to get one, and was satisfied with the pricing at MEC. I'm a long time member, love that store. It's also nice to handle the light a bit before buying it.
    Good job getting the lights into MEC.
  11. #791
    Nov 2003
    Quote Originally Posted by 4sevens View Post
    Hurray for MEC!
    This way I get to try it out a bit, and instant gratification. Plus, I remember when they began carrying Quarks - a good way to expose the brand to the public.
  12. #792
    Quote Originally Posted by calipsoii View Post
    Once they bring them in, my plans are to:
    a) open one up and see if it has the raised positive contact (signifying the new version)
    b) rip it apart and put a Nichia 219 in it
    Quote Originally Posted by jorn View Post
    I dont see how to do that. To shave off every mm, the led is mounted directly on the driver. If you try to reflow the led directly on to the driver, the ic's will fall off.
    Quote Originally Posted by Got Lumens? View Post
    Yes. You also need to bear in mind that it is a double sided circut board. The wave soldering on the LED side of the board would be no problem, but then you also have the second side to reflow as well. With the proper tools, and a ton(I mean TON) of patience, it would be doable. I only have a regular weller soldering iron station, and you would need an adjustable one with a small enough tip to remount all the other components after changing the LED out.
    NOT an easy project, but not impossible either.
    GL
  13. #793
    Nov 2008
    Norway
    Nice 219 job. hard thing to do?
    I simply use the pill from a neutral dqg. 5 and 60 lumen, so its waaaaay brighter
  14. #794
    Nov 2006
    Default
    Please explain how you did the mod!
  15. #795
    Nov 2003
    Ooh. Where are you, and how much would it cost to get a modded P0?
  16. #796
    Mar 2011
    Champlain Valley
    Now that's dedication
    Very Nice :
  17. #797
    Quote Originally Posted by Haesslich View Post
    I am in Alberta, though I don't know how comfortable I'd be working on someone else's light...
    Quote Originally Posted by gunga View Post
    Modding this light will guaranteed void the warranty. It might not work properly (if at all) afterwards. Attempt at your own risk.
    • remove the brass positive contact by applying a tiny bit of solder and heating it quickly with the side of your iron while working at it with tweezers
    • apply a tiny dab of solder to the pad beneath the brass contact, then heat that while prying at the LED
    • place the new LED and reflow it by heating the positive contact pad
    • replace the brass positive contact
    I know the underside of the pill looks pretty rough in these photos, but I was poking at it and heating it with the iron for almost an hour trying different things out. The next time I mod one I know how I'm going to do it.
    Left: Peak Eiger 219 (narrow) -------- Right: Preon P0 219
    Preon P0 219
    Overall impressions so far:
    • The threaded pill is made of very thin nickel-plated copper(?) or something equally soft. Alligator clamps and screwdrivers will dent it easily.
    • As with every 219 mod I've done so far, the light is brighter on High, but gets warmer a LOT faster. Lower Vf, etc etc.
    • Someone commented (I believe it was PoliceScannerMan) that the perceived color temperature of this 219 LED gets cooler as you go from focused -> flood. Having done this light, I would agree.
    • The beam pattern is no longer perfectly round, it's slightly square. I believe this is due to the larger die of the 219. Perhaps that's why 47's chose the XP-E? (or maybe they wanted a bit more throw)
  18. #798
    Flashaholic* skyfire's Avatar
    Dec 2009
    Los Angeles
    nice job on the emitter swap!
    i was planning on doing the same until i took out the pill and saw it.
    i figured spending a few hours modding a $20 light that is rarely ever used wasnt worth it, plus the fact that while attempting it i could easily destroy it
  19. #799
    Nov 2003
    PU was thinking of paying you to buy one and mod it... especially as the Edmonton MEC has it in stock, and Calgary should be able to get it easily.
  20. #800
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    Really amazing work Calipsoii! Great end results as well. Wouldn't it be neat if it was just made that way to begin with?
