135 lumens is not a measure of throw.
Lumens in a measure of the total output of light.
A common topic of confusion.
The total output of light in lumens is made of the brightness in lux, multiplied by the surface area of illumination.
Therefore total output (in lumens) = brightness (in lux) x lateral surface area illuminated (square meters).
From the formula, the greater the brightness in lux, the greater the total lumen output.
However, also remember that the greater illuminated surface area in square meters, the greater the total lumen output too.
Thus, the total lumen output represents both the brightness and lateral surface area illuminated combined.
Note that the brightness in lux, alone determines the longitudinal throw; the greater the brightness in lux, the greater the longitudinal throw.
Next time, for outright throw only, focus on the brightness in lux.
Lumens will also take into consideration the total lateral surface area illuminated in square meters.
You will find that the Predator will illuminate a much larger surface area [in square meters] than the 135 lumen $15 3D Maglite...
