Hello everyone, I've been lurking here off and on for some time but have found I can't seem to find a conclusive answer to what light I want from the threads here - so I would like to request some help in this decision. Knowing myself, I will probably buy more lights later and more expensive ones - but for now I would like to keep the cost relatively low at under $50. For years I have used my 2D cell Maglite, but compared to a Coast LED light my dad has along with some new tiny LED light he ordered I feel a bit outdated with my Maglite.
We commonly have storms here and power outage is an ever present risk. As of now, when stormy weather comes I have to carry around the Maglite which is a bit big. I can stuff it into a pocket but this feels awkward and doesn't hold the light real well. This is where I know an LED light could come in much more handy, small enough to fit in my pocket so I don't need to physically carry the light with me and set it down somewhere (I always think "And what are you going to do when the lights go out and you can't see where you put the flashlight?") - usually in my lap or somewhere else in the way that is easy to reach. I was sold on the Xeno E03 until I read several people complaining about flickering and noticing the plastic retaining ring - I had seen most of those people say the problem was in the switch and they either cleaned it or replaced it. I'd rather spare parts with a new flashlight be like the spare bulb on my Maglite - still tucked away, never used and hopefully not needed for many years.
Anyway, without further adieu I will answer the questions requested we answer when posting here.
I will be mail-ordering or buying online, so this doesn't matter. I'm not opposed to buying from a local store, but I sincerely doubt they'll have stuff as nice as what is available online.
2) Budget: An easy question, but you may change your mind after answering the rest!
Less than $50
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
Every day carry medium (4-7 inches)
5) Emitter/Light source:
LED (Specifically, Cree XM-L)
6) Manufacturer:
This would be my preference, but depending what the latter involves I wouldn't say I'm unwilling to try it ->I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
-I would consider getting a light that is pieced together
7) What battery type do you want to use?
This is something I liked about the Xeno - ability to use lots of different battery types. However, if forced to choose I'd rather use the rechargeable li-ion as I know they provide the highest output in these smaller flashlights. I would like to be able to use an alternative if possible - for example, 14500 or NiMH but I don't want this to limit my choices so key thing is the li-ion battery capability. (Btw, the 14500 is random - I have no preference for battery type as long as they're not outlandishly expensive, i.e. $10 a battery)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I'm probably leaning toward the prior, but if the latter is possible at this price point I'd be cool with it as long as it has a low level mode for using indoors and such
-I want to illuminate my entire backyard or a campsite (150-300 lumens).
-I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
I'd say somewhere between these - I'd prefer a little more throw over flood faced with the choice.
-5-20 yards/meters (check out a noise in the backyard)
-30-50 yards/meters (I have a big backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
Any of these is perfectly suitable for me - again a light that can run on multiple modes would be most ideal so I don't have to use up all the battery when using the light indoors.
-Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
-30-60 minutes (I have plenty of batteries just ready to be changed)
-90-120 minutes (Runtime is moderately important, but still not critical)
Perhaps a tad less than this - I don't want it to be a cheap piece of junk if it can be avoided (Otherwise I'd go for the lowest cost possible route). The Xeno would probably be the lowest quality I'd accept but only if I can find no better alternatives.
-Very Important (Camping, Backpacking, Car Glove-box).
12) Switch Type and location (choose all that apply):
I don't care.
I could potentially be satisfied with either of these - at minimum it needs to have a high and low mode, but say an ultra low and medium mode would be nice if possible.
-I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
-I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
These are cool, but I can live without them if the light does everything I want and lacks them.
-Pocket/belt clip
-Holster
-Wrist/Neck Lanyard
Not opposed to buying from a company straight out of China, just want a light that has lots of positive feedback before I do so. Also, from looking at Xeno's website I see them talk about non-PWM and of course no flicker - but I noticed one of the flashlights (I forget now I've looked at so many on here) was PWM and it was really noticeable the flicker. I definately do not want flicker (Not that anyone does) - so I'll probably steer clear of any PWM lights. I know my order is tall for under $50 - but I honestly didn't know a good 2/3 of these flashlights existed just a few days ago before I started looking so someone may know of just the right light for me. My price range was originally $30-$40 (Perhaps the Xeno E03 spoiled my idea of pricing) but could maybe bump a bit over $50 if the light is really worth it.
Less than $50
3) Format:
6) Manufacturer:
I don't care.
-Pocket/belt clip
-Holster
-Wrist/Neck Lanyard
