Rookie Ohm\'s question...
Ok, I'm still a rookie. So I apologize if this has been asked a gazillion times. [That's more than a gabillion, right?] Did a search but didn't really find the answer.
Well, I have done a few newbie mods. One of the 9V ones here. And my first PR Bulb Mod here.
The question I have is, in the few mods I have done, I supplied the power supply and resistor connecting them to a single LED. Very basic and not using any regulation, yet. What I want to know is... what determines at what current/voltage is the LED being driven?
Say I use 6V. [4AA] and a 100 Ohm resistor. At what current/voltage is the LED being driven? 4V at 20mAhs or 3.4V at 30mAh, since both value combinations fit the formula. Does the LED consume as much current as it can? I used LED_Pro to get and verify the values.
I guess I can open the circuit and hook up my multimeter as an ampmeter. Just thought you guys could shed some light [pun intended] the subject. /ubbthreads/images/graemlins/help.gif
Danno
Danno
