Gaggione LLC49R - A good throwing optic for XM-L
The_bad_Frag
Germany
I just recived a Gaggione LLC49R from led-tech. Those are really nice. This is the first optic for XM-L (that I know) which has some good throw.
Here are some pics. Its fitting perfect on the copper pcb XM-L! :)
I will do some beamshots when I mounted it. I already held it on my energizer XM-L and I really like the throw of it.
bshanahan14rulz
Tennessee
With size like that, it BETTER be a good thrower! It will at least have higher lux than a comparable reflector, I'd imagine.
Hill
MA
Very cool looking optic. Any idea what host it will fit?
The great thing about optics is they are shallower than reflectors allowing for more heatsinking.
LED-TECH site is currently down :-(
archer6817j
Mountain View, CA
Does it still fit on the mcpcb after you solder the wires on? I've found 90% of optics I've tried fit great...until you actually try to hook them up. I'd be interested to know the size as well?
The_bad_Frag
Germany
Now some pics from the first test. :D
Your solder connections need to be 1,1mm or less in height. So just keep them flat like I did. Shouldnt be difficult for someone who already soldered a bit. Just dont make those "mountain tops" when you pull the soldering iron away. :D
My silicone wires are a bit bigger than 1,1mm in diameter so I have to apply slight pressure to the optic to get it all the way down on the pcb.
If you want to screw that copper pcb down you have to countersink (I hope its the right word :D) the mounting holes and use screws that align with the surface of the pcb.
Gaggione LLC49R
triple XM-L Mag
I just put that XM-L on a cpu heatsink and DD it of 3 AAA eneloops. Those were only 40-50% charged and there was so much resistance in the test circuit that I only got ~1A current. :D I dont have a driver for it atm so those beamshots are not comparable! (+different exposures!)
The beam of the optic has about the same size as the hotspot of my triple XM-L mag with DW kit reflectors. There is not much spill. I think only 1 XM-L at 3A can throw better than my triple. Dont worry I only use that energy-saving bulb-crap because I didnt ordered a led for it. :D I HATE those lamps!
pavithra_uk
SRI LANKA
I have this optic. unfortunately it never fit with standard star MCPCB. have to cut tiny 2 bumps. and can't use MCPCB screws.
Didn't found holder for that optics.
Al Combs
The datasheet in The_bad_Frag's link says the LLC49R optic on an XM-L has an efficacy of 36.4 Cd/Lm. So if your XM-L was a 1,000 lumen U2 bin, that would be 36,400 lux @ 1 meter. The beam half angle at 50% is 3.7° and half angle at 10% is 6.6°. So it basically has a 13° hotspot. Besides the XM-L U2, I checked on Cd/Lm figures for the XP-G S2 and the XP-E R3. They are all very close but the XP-E R3 has the brightest hotspot of the three at just over 40K lux.
Not as good as your 127K lux XM-L Franken Mag Shorty ma_sha1, but not too bad.;) Like you said, kind of floody. Considering the hotspot diameter looks identical to Der Wichtel's triple and that you'd need a light as big as a Mag to hold a 45mm TIR anyway, I think you'd probably be better off with a Rebel Mag reflector for throw. Even after allowing for the TIR's absence of spill.
The_bad_Frag
Germany
I just did some quick testing with my old crappy lux meter.
Here are the results:
210 lux - triple XM-L T5 Mag DW kit @3A ucl lens
160 lux - Gaggione LLC49R + XM-L T5 @~2A
125 lux - Energizer mod with energizer reflector(almost the same beam as stock mag D reflector) XM-L [email protected] stock lens
60 lux - Wolf-Eyes Krait
55 lux - triple XM-L T5 Mag DW kit 1x XM-L @3A ucl lens
I also did a super quick test outside and it looks throwy to me. At 100-150m it illuminates everything with almost the same bightness as the triple mag. I need to get a driver to run it at 3A and then test again.
gt40
bainbridge island
I was wondering about this optic. Ordered some of the Mobdar extra narrow 6° and 3 of the same xm-l u2 on copper for smaller lights. Is there a point vs aspheric? I mean you are getting to a size light that you could fit a decent aspheric in a this point...
The_bad_Frag
Germany
You can use glue if you want... ...but I would use the body of the flashlight to press it against the star. When you glue it you will destroy the star/led when you try to remove it.
Hoop
Spokane, WA
Is it your observation that this optic produces less of the yellow/green corona that xml's display when using reflectors? The beamshot looks quite white for an xml.
The_bad_Frag
Germany
No this is because I took these shots with the cam in auto mode. In reality it gives the led a warmer tint than it would have without the optic. I would say its about the same as a reflector.
Yesterday I got some rebel reflectors and when Im able to focus them good on the led I will do a comparison. Somehow I get a hole in the middle of the beam or a very floody hotspot with the rebel reflector. Its not looking like beamshots here.
nc_hooper
Just got mine in. Mounted in a 2D mag with an XML-T6 running at 3.1 amps.
The way I mounted it into a standard mag head by grinding off the tabs at the end and the tab on the side. Then I resized a large rubber washer and used that to push the optic against the lens. Worked quite well and is tight and well centered. And you can de-focus it for a larger spot.
Did various subjective comparisons - using a standard/rebel reflector and a FM throwmaster head. Also tried a Malkoff XP-G dropin. Liked the XML better - it has a larger spot but is brighter. Really liked the minimum spill - that's the main advantage for me with this optic. It does not throw as far as the rebel reflector and nowhere close to the 2.5" FM Throwmaster head. But it seems to put out more lumens (based on a very subjective ceiling bounce test). Of course it has a larger spot size then these reflectors. I was most impressed when I compared it to my M6-Septa SST-90. Lumens factory claims 1600 lumens for this, but probably closer to 1200 lumens. The XML is producing probably 800 lumens at most. Anyhow, when compared, the spot size is a bit bigger for the optic and considerably brighter (with a lot less spill). Another comparision I did was with my Malkoff Wildcat V2 (3x XPG with reflectors) - the optic has a smaller spot and is considerably brighter.
Al Combs
Just for clarification, was the tab grinding at the end necessary because you used something other than The_bad_Frag's copper star? What kind of heatsink did you use in your 2D Mag? I was thinking of trying a Bad_Frag copper star and TIR on an H22A flattop in a MagLite. Would make a nice everyday utility light in a Mag-C with a single 26650 and a 2.8 amp linear regulator. Maybe a few extra 7135 chips soldered on to take that copper star for a test drive.:) But I'm not sure if the H22A flattop is too tall. What do you think?
I was most impressed when I compared it to my M6-Septa SST-90. Lumens factory claims 1600 lumens for this, but probably closer to 1200 lumens. The XML is producing probably 800 lumens at most. Anyhow, when compared, the spot size is a bit bigger for the optic and considerably brighter (with a lot less spill). Another comparison I did was with my Malkoff Wildcat V2 (3x XPG with reflectors) - the optic has a smaller spot and is considerably brighter.
I thought the same thing from the The_bad_Frag's lux measurements in post #10. The relative measurements shouldn't be affected by his use of what he called a, "crappy lux meter". I did the backwards math from Cree's XM-L data sheet graph, "Relative Flux vs. Current". If you reduce the current from 3 amps and 210 lux down to 2 amps should be ≈158 lux. So his 160 lux result at 2 amps means it would throw about the same as a triple if he had a 3 amp regulator. That of course assumes similar T5's. I would not have thought you could get that much extra light from just utilizing the spill. Even an aspheric that has no spill, to triple the output of a similar sized reflector hotspot is quite good. Very impressive results.:thumbsup:
nc_hooper
Al - the tab grinding at the end was due to my specific configuration. My LED is mounted on a ground-down star on a short 12mm wide post which then expands to the width of the battery tube and forms an aluminum heat sync. This is one of JayRobs Mag Mods using 2x32650. Anyhow, the power wires have a small loop close to the LED; I needed to grind down the tabs so the optic could clear these wires. I had to grind down the side tab because how I mounted the optics to the head (using a large rubber washer, pushing the optic into the front lens). With the side tab in place, the washer would not work unless I cut a notch into it.
Al Combs
Could you give an estimate of where the tip of the LED is relative to the front of the Mag battery tube? Does the LED protrude from the front of the battery tube? Or is it recessed like it would need to be for a Rebel reflector? Do you have any pictures? Thanks in advance...
nc_hooper
I could take a close look this evening. But basically it's in a position similar to the standard non-rebel reflector - so it's slightly recessed. It could go a bit further forward because the optimal focus location is slightly out from screwing the head down entirely. I'll if I can get a few pictures this weekend.
