I am not confident the numbers on that website are correct.
aluratek is a general electronics company. I do not think they make the bulb. Probably just repeating numbers given to them by the manufacturer.
- Voltage: AC85-265V.
This indicates an Asia made bulb. Its 220-240V over there. All other specs could be at 220V. May not perform as well at 120V.
- Service Life: 50,000 Hours.
Looks like the manufacturer just copied the number off Cree or Lumileds website. The 50,000 hours is based on 25°C. The LEDs in a lightbulb is ~85°C. (Reminds me of SSC-P7 torches at DX claiming 900 lumens when most actually measure ~500 lumens because SSC had 760-900 lumens up on their website at one time. SSC have since revised the number to 700-800 lumens but 900 lumens stayed on the torches.) The heatsink is too small. Usually used in 5*1W up to 7W. They are pushing 10W into it further raising the temperature. (When the XP-G 1st came out Ultrafire just swapped them into an XR-E based module. The failure rate was horrid - lack of heat sinking.) The Evolux 2 from EarthLED has a much bigger heat sink.
- Temperature (Kelvin): 10W 4500K-6500K (850lm) - 2600K-3700K (720lm).
Dead giveaway the manufacturer is buying whatever crap LEDs they can find on the open market. 4500K is neutral white. 6500K is cool white. The Quality control of a bulb whose tint can vary from 4500K to 6500K is suspect. A comparison of 4500K vs 6500K tint here:
http://www.candlepowerforums.com/vb...lights-do-you-love-em-If-not-take-a-look-here!
- Light Output (Lumens): 10W (850lm - 720lm).
If they are really that good why is that bulb not entered in the L-Prize competition?
Light angle 130°
The Philips 800 lumen, the Ecosmart (Lighting science) 850 lumen,and the Utilitech 60 Watt LED all have wider angles.
- Certification: UL / CE / RoHS / PSE.
Ask for the UL number. Then check it out on UL's website.
Price - $29.99
At Home Depot:
Philips Ambient LED 12-Watt (60W) A19 Light Bulb 800 lumens - $24.97
EcoSmart 13-Watt (60W) A19 LED Light Bulb 850 lumen - $23.97
To the OP,
I probably will take the Evolux 2 or Tuwago over this one.
Hijack
Commenting on a different thread by the OP.
I got my Lighting science 60W from Earthled. The light is a ring with a dim rather dirty looking center. Not suitable for an exposed bulb.
If the light is a ring with a black center I would not mind.
