Hello All,
I couldnt help notice them lights at Costcos too,
so i picked up a pack
Of course i had to open one up too, and did a full
analysis of the circuit.
I've found the circuit to be WAYYYYY over complicated,
with wayyyy too many parts for what it does, and not
only that, it tries to do too much as well. Do you
really have to turn an LED night light off during the day?
The basic circuit (not the sensor part) is very similar
to my own circuit on my home page. The main difference
is they use a 1/2w flameproof resistor for the input
resistor instead of a fuse. I like the fuse better,
but the flameproof probably isnt too bad either.
The input cap is 0.56uf.
Since they added the CdS sensor they had to provide a
circuit to go with it, which takes two transistors and
some other minor parts. Not only is the circuit overly
complex, a slight change in design would have allowed them
to use a cheaper transistor and also eliminate the 56uf
electrolytic cap they used for filtering the signal
used to turn on/off with the sensor (note the cap ISNT
used to filter the line frequency to provide a more
constant light output! amazing as this sounds).
Ok, now for the good points...
The price is ever so cheap! Six for $10.00 USD.
This probably wasnt the original retail cost i bet.
They put out a nice white light, not tinted.
The case is one of the best i've ever seen. Heavy
1/8 inch plastic with a heavy clear plastic diffuser.
You cant ask for more then this. I bet you could stomp
on it with your foot and not crush the body where the
electronics is located! The price is worth getting
the case alone if you wanted to build your own.
Since the price is so good it doesnt matter about the
complex circuit, but i wonder if this product will
always be found for this price?
