Ok,
This thread contains some speculation about the upcoming 5W LED heads/systems from SF so if that gets under your dentures, you might want to skip this post. However, if you suspect that the KL6 head will be the most extreme performance head SF will release in the near term(?), and you would rather not pay a $100 premium for the M3 body tube to use it with, then read on.
The fact that the KL6 is designed or use with the M3 and M6 implies that it will be the highest performing model (speculation alert). The fact that the M3 seems to have a head that is incompatible with the C3 or M2 implies that the threading must be different (speculation alert). The fact that 3 cells is three cells, at least as a power source implies that the KL6 head should work on the C3 or P3 bodies as well as the M3 (speculation alert).
Having said all of the above, what I would like is the ability to run the KL6 head on the C3 body (not too bad looking and suiting my casual torch usage) instead of the way too complicated, clunky and expensive, high tactical functionality M3 body.
So, the simple and not speculative question I ask is this: "What would it take in terms of an adapter to run an M3 bezel on a C3 body tube?
Wilkey
Wilkey
