T g
I currently have a Ultra Fire SSC P7 bicycle lamp.
It runs on 4 18650's and the pack puts our 8.4 volts.
I have a spare battery Ni-Cd 9.6 volt spare pack.
What will happen if I wire this pack into my light?
Well, your 9.6 v pack will put out about 11.2 volts when fully charged, which is indeed slightly more than 8.4 volts -- 33% more. (Obviously your current pack is wired in a 2s2p configuration.)
However, the odds are that your light has a regulator in it (and enough tolerance that it can handle 11.2 volts) and so it'll be fine. This is not certain, however -- you do have a chance of ruining your light.
If it does work fine, it will probably not be any brighter than it was before. (And if it is brighter than it was with the stock battery fully charged, I'd suggest immediately stopping the use of this new battery before it fries. (It might work forever, or it might fry.) The odds are that if it the higher voltage will fry your light, it won't do it immediately, so you'll have a few seconds to test -- but I wouldn't push it much longer than that if it is indeed brighter.
To be more precise about all this would require knowing what's inside your light, which I do not.
