I want something to replace my current LED MagLites, as my 6D and 3D are my current throw champs. So what I want is something to equal their throw, but more compact and with better spill. Outright throw isn't the aim, but it'd be nice to have something that can light up the hedge on the other side of the field.
My initial thoughts where:
-Klarus XT11
-EagleTac G25C2
Although I have also been looking at the Klarus XT20, but I think the 2 x 18650 make it a bit big to carry about easily or slip into a jacket pocket. I then stumbled across the Maelstrom S12 and X10. They seem similar in size to the G25C2 but packing a tad more punch.
The Maglite 3D and 6D are pretty good throwers, throwing some 400 meters ANSI FL-1 standards, give or take.
The Et G25C2 with it's small 39.5mm bezel diamerter will only throw 245 meters ANSI FL-1.
The Klarus XT-10 XM-L T6 only throws 161 meters as tested by Selfbuilt.
The XT11 XM-L U2 has a 7% brighter bin, so it will throw a little better.
These 1x18650 powered single XM-L's with small diameter reflectors 30-40mm throw well short of Maglites.
If you want similar throw to the Maglites, but more compact in size, and a
moderately wider hotspot and a brighter lateral spill, try the 2x18650 powered single XM-L's with 60+mm reflectors like the Crelant 7G5, Olight M3X, Sunway T40CS, Catapult V3, Eagletac M3C4 XM-L, Olight SR51 XM-L, Sunway V60C, and the hybrid TIR total internal reflection Surefire Invictus UB3T XM-L powered by 6xCR123's.
The Xtar S1 3x18650 Triple XM-L has a huge bezel diameter of 83mm, but will throw even further than the Maglites to 470 meters ANSI, and provide a
whole lot more flood; it is more compact, but very wide in bezel diameter.
Else, an Olight SR92 6x18650 Triple XM-L will throw a similar 425 meters with a helluva lot more flood, but it is oversized with a 100mm bezel diameter, and weights some 1.5 kg including batteries...
