Hi,
I've got hold of a non-working Gilan Pocket Torch. Originally it has a 35mm 35W Halogen bulb but I'd like to upgrade it to a triple XML board with the Ledil Cute triple spot optic.
The torch takes 8 x AA batteries (in a standard 4 x 2 holder). It might be possible to put a different battery pack in there, but the space is 37mm dia x 115mm, so I doubt it.
I've modded a couple of torches (an XML in a 3-D Maglite and a Maglite based umbilical dive torch) but I'm very much a beginner and I'm a bit confused about the power supply I need.
My eight-cell NiMH pack will give me 9.6v. This should be enough to run the triple XML, but will the batteries be able to provide 2-3A (even if just for 45 minutes)?
If I decide to use a constant current driver at say 2A do I use a buck or a boost, or does it not matter? As I understand it for a buck the voltage has to be at least 1v above the required voltage, I assume there has to be a similar difference with a boost driver - so in this case is the difference too small?
How about using two XMLs? If I use the triple optic with just two LEDs is it going to look odd? It would mean that I could need a lower voltage and make it easier to select a driver.
Thanks,
Neil
Thanks,
Neil
