Crelant
Results 1 to 29 of 29
Thread: what to do with SF incan lamps?
    Default what to do with SF incan lamps?
    I have a few old "high pressure xenon 9v" and p60 lamps that work fine but i have converted to malkoff dropins and was wondering if anything can be done in terms of modding the lamps or if i should just throw them away. let me know your ideas. thanks
    Flashaholic chewy78's Avatar
    Feb 2008
    wi
    Default Re: what to do with SF incan lamps?
    send the 9 volt ones my way
    Flashaholic* archimedes's Avatar
    Mar 2011
    CONUS, arteriosus
    IF 2 = 1 THEN 1 = 0
    Moderator Kestrel's Avatar
    Oct 2007
    The Willamette valley, in Oregon
    The "9V" lamps are still quite usable and even desirable by some here due to their compatibility with two LiIon rechargeables in series - the voltages of 3xCR123 (what these lamps were designed for) and 2xLiIon (a very popular rechargeable configuration on CPF) are very similar.
    The "6V" lamps don't have many uses IMO, one very good one is the one that archimedes linked to.
    In the past we have had a light which flickered, in the present we have a light which flames, and in the future there will be a light which shines over all the land and sea.
    - Winston Churchill
    Thread Killer Illum's Avatar
    Apr 2006
    Central Florida, USA
    P60s aren't too bad actually... they run wonderfully at 5V (~1.15A). A decent holder and a simple power supply these work better than the 12VAC Halogen bi-pins for painting lights.
    Flashaholic* yifu's Avatar
    Oct 2011
    Australia
    If you want to mod them, probably not a good idea, it's much better to get a bipin socket/reflector from FiveMega and chosing your own bulb. But, put them up at the marketplace! There's still demand for these things, if sufficiently cheap.. Hint hint.
    Aug 2004
    Sacramento
    Welcome to CPF!
    Just keep them.
    kelmo
    I've used the P60 lamp in a Surefire with a single 17670. A nice soft warm glow emits for creeping around the house at night. I ended up with a few P60 lamps after modifying the Surefire hosts for an LED or brighter incandescent lamp. Some people say that the low voltage will make them turn black, but mine is still crystal clear. You could buy cheaper hosts and install the P60 and an 18650 to give you longer run time. Welcome to CPF!
    Flashaholic* M@elstrom's Avatar
    Oct 2007
    Sunraysia, Australia
    + 1 HotWire I do exactly the same with my Surefire, Streamlight & Brinkmann incandescents without issue...
    My modest collection HERE & 55w HID spotlight project HERE
    Flashaholic* cland72's Avatar
    Nov 2009
    Texas
    Quote Originally Posted by Kestrel View Post
    I love using 2x17500 batteries in my stock 9P. Free lumens with the most HCRI output you can get.
    As for the 6V bulbs, I have them in my "rainy day" stash in the unlikely event EMP affects LED drop ins/flashlights. You can't get but about $10 per P60, so for that price I'd just assume keep them around in case they are needed.
    Chris
    Flashaholic* Chrontius's Avatar
    Oct 2007
    Orlando, FL
    I use a lot of LEDs around here, but I keep the incans around for color rendering, or sudden flights of fancy.
    A 6R conversion kit can be had cheaply if you can find a B65 compatible stick; the charger and conversion tubes are on clearance at LA Police Gear.
    So, is there no problem running a P90 with 2xRCR123s? I tried it, and it is nice...
    What about using a P91 with 2xRCR123s?
    This doesn't under-drive thebulb?
    Jun 2010
    Norway
    It underdrives it slightly (8.4V off the charger, 7.4V continuous vs. 9V). I don't remember what the voltage/discharge curves are like for CR123s vs. li-ions so I don't know if that's worse, better or just similar.
    Flashaholic* fivemega's Avatar
    Jan 2003
    California
    Quote Originally Posted by justlooking View Post
    If you are refering to protected RCR123s, both P90 and P91 will be over 2C limitation of cells discharge but P90 works excellent with pair of IMR 16340 and P91 overdrive but still safe (shorter life) to run with mentioned setup.
    Quote Originally Posted by jellydonut View Post
    Both P90 and P91 are NOMINALLY 9 volt.
    P90 works well with 7.5~7.8 volts and P91 works without overdriving at 6.6~6.8 volts.
    So drive P90 with pair of IMR16340 with confidence and P91 knowing that it will overdrive but still safe.
    For your information, each brand new and never used primary CR123 has about 3.2 volt open cirquit, drops to about 2.5 volts under load of (P90) 1.2A and drops even further down to about 2.2 volts at (P91) 2.4 Amps.
    Each healthy and fully recharged IMR16340 has about 4.2 volt open cirquit, drops to about 4.0 volts under load of (P90) 1.2A quickly and drops even further down to about 3.7 volts at (P91) 2.5 Amps.
    Oct 2007
    Orlando, FL
    So, counting overdrive, how much is a P91 on a pair of IMR 16340 putting out?
    Jun 2010
    Norway
    Quote Originally Posted by fivemega View Post
    So in other words 3x CR123 in practice provides around 7.5 volts - perfect, then. Thanks for the clarification, I was unsure.
    Thanks jellydonut and fivemega, for the clarification. I was, in fact, using AW protected RCR123s. Guess I won't do that again! I knew it sounded too good to be true.
    I thank you, and my fingers thank you!
    Oct 2007
    Orlando, FL
    In my long experience, (if only with this ONE setup) a P91 and AW IMR 16340 setup is safe... but I wouldn't have dared using that on LiCo cells.
    Jan 2003
    California
    Quote Originally Posted by Chrontius View Post
    My esimate will be 400~450 BULB lumens at start of fully recharge cells.
    3x CR123 in practice provides around 7.5 volts under 1.2 Amps load.
    Unless longe run time is needed. For example if host can take 2 protected 18500, then run time will be almost 3 time longer than 2 IMR16340
    Flashaholic ToyTank's Avatar
    Sep 2011
    Your Momma's house...
    I have 2 P60 I burnt using lifepo4. They ran for only an hour or so now I know better.
    I like the mod Archimedes linked to and I may need to make something similar.
    I have one with a 4x20 tritium vial in it to make a trit torch. Works well but weak compared to 15mm sphere with reflector.
    I also run a P90 on 2 X 16340 IMR cells. Nice bright light. Short run time. It's great around the house or close to a charger. When traveling I install a P60 and use primaries in the same light. Not as bright, much longer run time. I keep a supply of charged 16340 IMR cells at home for quick changes. That is not the light for non-flashaholics because the cells can be damaged by discharging them too much.
    I run a P90 in a G3 with 2XAW17500's all the time without incident.
    Finally seeing the light - going back to incans!!!!
    Jan 2003
    California
    P90 works very safe on 2 protected 17500
    P90 works very safe on 2 protected 17670
    P90 works very safe on 2 protected 18500
    P90 works very safe on 2 protected 18650
    P90 works very safe on 2 IMR 16340
    P90 works very safe on 2 IMR 18350
    P90 works very safe on 2 IMR 17670
    P90 works safe on 2 IMR 18650
    P91 works safe on 2 protected 17500
    P91 works safe on 2 protected 17670
    P91 works little hard on 2 protected 18500
    P91 works little hard on 2 protected 18650
    P91 works safe on 2 IMR 16340
    P91 works safe on 2 IMR 18350
    P91 works hard on 2 IMR 17670
    P91 works very hard on 2 IMR 18500
    P91 works very hard on 2 IMR 18650
    Oct 2007
    Orlando, FL
    I'd only dare using it for about 10 minutes on a charge, or perhaps 3 minutes at a time for fear of heat. But it's quite an impressive few minutes!
    That's an excellent chart, by the way. It looks like it only covers bulb life concerns, but it's excellent to know.
    Flashaholic greatscoot's Avatar
    Dec 2011
    Illinois
    Quote Originally Posted by HotWire View Post
    What kind of runtime do you get?
    "Klaatu Barada Nikto"
    Smile Re: what to do with SF incan lamps?
    Hi everyone,this is my very first post in the forum.a few years back my buddy gave me a surefire ,my first surefire an e1e.since then I fall in love with surefire incandescent light,I sleep with a 9p under my pillow.feel much secure.nothing out there beat the glory beam of the p91.
    Oct 2007
    Orlando, FL
    Welcome to CPF, LittleLantern!
    Your friend sounds quite generous, and an E1e is a great choice. You might want to stock up on bulbs pretty soon, but those things are remarkably solid little lights.
    Aug 2006
    NYC
    Thankfully Lumens Factory is still making replacement bulbs for SureFire's older Inca. models.
    Stocking up on E1E bulbs shouldn't be a problem. But yeah, better done sooner than later.
    Hi there, when the time I got the e1e,I m a regular guy with little knowledge about flashlight and yet become a flasholic,all I knew is change the battery once a week .Then one night the e1e failed to worked, I frantically look for the replacement lamp and got some 250 miles down south,I tried to modify several bi pin xenon lamp to replaced to mn01 but none of it beat the hotspot, beam quality ,runtime and the reliability of the mn01.stockpiling is a must .I tried before the lumens factory eo 1 r 90 lumens ,quite bright and shorter runtime.the p91 and p 90 is the most prized possession in my collection.
