Klarus
Page 5 of 28 FirstFirst 12345678910111215 ... LastLast
Results 121 to 150 of 814
Thread: P60 modules -warm, neutral, cool white/XRE-XPE-XPG-S2-XML-U2 / NICHIA 92CRI (part 10)
  1. #121
    Default Re: P60 modules -warm, neutral, cool white/XRE-XPE-XPG-S2-XML-U2 / P60 modules (part
    DAVE, I SENT YOU $45 VIA PAYPAL FOR P60 DROP IN, XML U2, 2.8-6 VOLTS W/MEMORY, 3.1 AMP., 3 LEVEL (l,m.h,regulated) SMOOTH REFLECTOR. MY HOST IS A SOLARFORCE L2 AND USING 2 PRIMARIES OR 1 X 18650. THANK YOU, DENNIS07921/DENNIS CARLSON
  2. #122
    Flashaholic chewy78's Avatar
    Feb 2008
    wi
    Christo Pull Hair Re: P60 modules -warm, neutral, cool white/XRE-XPE-XPG-S2-XML-U2 / P60 modules (part
    i myself am still trying to decide between t6 3c and t5 4c xml
  3. #123
    Feb 2008
    wi
    Cree XM-L $40
    T50 flux Bin 4C 4300K neutral white
    3 level Low / Med / High Regulated with memory 2.8-6 volts at 2.8 amp
    op reflector
    with thermal Potting and copper tape + $5.00
    $45
    will be used in a solarforce l2p host with an eagletac 3100mah 18650
  4. #124
    Quote Originally Posted by dennis07921 View Post
    Quote Originally Posted by chewy78 View Post
    Cree XM-L $40
    op reflector
    $45
    Hi
    All orders have shipped.
    Thanks
    Dave
  5. #125
    Hi All
    I now have in hand the new Nichia 4500k neutrals 92+CRI emitters. They will be priced the same as the XPG's
    Thanks
    Dave
  6. #126
    What will you use them for? The best way to decide is get them both and see. If one is clearly better sell the other on MP. You may find each is better for different things and keep them both.
  7. #127
    Quote Originally Posted by nailbender View Post
    Hi All
    Thanks
    Dave
    What can you tell us about them? Amps, higher amps, color change with higher amps, heat, beam, Lms compared to XPGs, anything else? I'll have to try one just to satisfy myself Also, how's the beam with a LOP vs smooth?
  8. #128
    I tried to PM you but you're full. Again
    Cree changed what's at the link you post in your xml description in the first post
    and the info there is useless. Here's binning
    http://www.cree.com/~/media/Files/Cree/LED Components and Modules/XLamp/Data and Binning/XLampXMBL.pdf
    and Datasheet
    http://www.cree.com/~/media/Files/Cree/LED Components and Modules/XLamp/Data and Binning/XLampXML.pdf
  9. #129
    Quote Originally Posted by RCantor View Post
    and Datasheet
    Hi
    Thanks for the link, I will change later today.
    My PM is not full it was cleared yesterday
    Dave
  10. #130
    Hi
    Dave
    Sorry, it was *my* box that was full!
  11. #131
    Apr 2008
    Cleveland,Oh
    Dave,
    In your opinion, is the 9v max driver, or the 6v driver (the 1.4Amp) more efficient for a single Lithium Ion battery?
    I would like the option of 2x RCR123, but will primarily be using an 18650 cell.
    Great spirits have always encountered violent opposition from mediocre minds.
    -- Albert Einstein
  12. #132
    Quote Originally Posted by jabe1 View Post
    Dave,
    HI
    If most of the time you will be using a single li ion then the 6 volt max is better. Most of the 9 volt drivers have a 3.6 or a 4 volt bottom end versus the 6 volt having a 2.8 bottom limit.
    Dave
  13. #133
    Apr 2008
    Cleveland,Oh
    That's what I thought. I'm just looking for the most versatility.
    Although it's not like I don't have alot of lights around at any given time.
    Thanks.
    Nichi High CRI, 3 level 6v max, 1.4amp, potted.
    -- Albert Einstein
  14. #134
    Thanks.
    HI
    thanks I will send it out Monday.
    Dave
  15. #135
    Default Re: P60 modules -warm, neutral, cool white/XRE-XPE-XPG-S2-XML-U2 / NICHIA 92CRI (part
    Here is a comparison of a Cree R4 XPG 5B3 and the new Nichia. I will see if I can get a better picture because to my eyes the Nichia is not near as rosy as the camera brings out.
    It is a nice tint and I think the camera is picking up the higher 92 CRI of the Nichia but here is something to look at.
    Cree on left Nichia on right.
    Both are running at 1.4 amps, and both are using the small aperture lop reflectors I use for XPG's I will try a smooth later. Again in real life the Nichia to my eyes is not that rosy. It does bring out the greens and browns outside quite well.
    Dave
  16. #136
    And of course we want to know if you can Linger these new Nichias...
  17. #137
    Flashaholic OtisCampbell's Avatar
    Aug 2009
    Boston
    I'll take a Nichi Neutral 92 CRI, 3 level - 6v with memory, potted, Priority shipping...
  18. #138
    Hi
    They are the same size as a XPG so that should not be a problem, as for beam quality I would not know until one is built up but I would imagine about he same.
    Dave
    Dave
  19. #139
    Moderator Kestrel's Avatar
    Oct 2007
    The Willamette valley, in Oregon
    I now have in hand the new Nichia 4500k neutrals 92+CRI emitters. They will be priced the same as the XPG's.
    Do you happen to have any detailed info on their Vf and how well they might work with low drive currents & wquiles's joule thief board?
    I'm thinking of one of those emitters instead of an XP-G ... ?
    In the past we have had a light which flickered, in the present we have a light which flames, and in the future there will be a light which shines over all the land and sea.
    - Winston Churchill
  20. #140
    Quote Originally Posted by Kestrel View Post
    HI
    Here is the DATASHEET . These are VERY close to the same specs as a XPG with a VF of 3 volts and I think they would be a great candidate for the Joule thief.
    Dave
  21. #141
    Flashaholic* Hondo's Avatar
    Oct 2005
    SE Michigan
    For:
    Two modules, identical:
    92 CRI 4500K Nichia 219
    3 level high / med / low (unless low / med / high is possible)
    2.8-6 volts with memory / 1.05 amp
    OP reflector, potted with copper tape
    Hosts: Solarforce L2P w/1x18650
    ​Thanks, Dave!
  22. #142
    How Could I resist?!?! potted Nichia linger LMH for me! Try the smo and OP reflectors and give me the one you think is best. I still have the diffusion film you recommended. I wouldn't mind some extra oomph in the throw dept if it exists.
  23. #143
    What flux bin are your Nichias?
  24. #144
    May 2003
    Colorado
    Paypal sent for:
    Nichia 4500k 92CRI neutral
    3 level high / med / low 2.8-6 volts with memory / 1.4 amp
    OP Reflector
    Potting
    I will be running the module in a Solarforce L2P with an 18650.
    Thanks!
  25. #145
    Hi
    All the nichia's came from the illuminaion supply company. The nichia's are NVSL219AT-H1 4500K, 92 CRI, B10 Bin
    Dave
  26. #146
    Flashaholic OneBigDay's Avatar
    Nov 2009
    Minneapolis, MN
    Hello Dave,
    Hope you are recovering well.
    (1) NICHIA / 4500k 92CRI neutral ($35) / OP Reflector / 3 level / 2.8-6 volts / 1.4 amp / potted (+$5)
    (1) Cree XM-L $40 / T60 flux bin 3C 5000k daylight white / OP Reflector / 1.7 amp (XP-G driver)/ 3 levels / 2.8-6 volts / potted (+$5)
    A 1.7 amp XM-L is a great option for hosts with smaller capacity cells or poor heat dissipation. I am really liking the 3C tint but want to check what all the excitement is around the high CRI Nichia.
    Thanks again for offering such a great service!
  27. #147
    Flashaholic* CarpentryHero's Avatar
    Jul 2010
    Edmonton
    Can you make a Nichia hi cri Linger special* 2.8 -6 volts* with Hi, low regulated*?
    Would it still be $45 for the linger plus $5 for international shipping (Canada) ?
    I'm glad I found CPF, I was beginning to think I was strange
    I'm a Canadian and a proud Flashaholic
    Thanks CPF, thanks Think2x
  28. #148
    Quote Originally Posted by CarpentryHero View Post
    Hi
    Yes I can make a 2 level * high , Low * and all my modules are regulated if they have levels.
    Yes the price is correct for both the module and the shipping.
    thanks
    Dave
  29. #149
    Jul 2010
    Edmonton
    I copy and pasted, that's why regulated is in there, thanks for clarifying that's in the multi modes.
    PayPal Sent
  30. #150
    PayPal Sent
    Hi
    Thanks, I have a to take my dog to the Vet tomorrow so it will ship on Wed.
    Dave
