Sold/Expired P60 modules -warm, neutral, cool white/XRE-XPE-XPG-S2-XML-U2 / NICHIA 92CRI (part 10)
Status
Not open for further replies.
nailbender
North Carolina
PART 9 !!! P60 Style Custom Drop - in modules for SF and other Products. (part 9 can be found here)
Here I am offering P60 Style drop ins, they are available with Leds from the following manufacturers with some of the leds that will be offered are below.
SSC Seoul - P7 , P4
Cree -
XML , XPG, XP-E, MC-E, XRE , UV, are here in warm , neutral or cool white
Osram - Diamond Dragon , Golden Dragon Plus, Platinum Dragon IR/
Luminus - SST -50, SST -90
These modules will fit most flashlights that accepts a standard P60/D26 Style module.
THESE DO NOT FIT OLD STYLE G2 HOSTS
IF a GREAT host is needed here are some great hosts by Five Mega to look at (HERE)
Here is one of the emitter in the base and converter board
View of the module from the top and typical beam shot
You can still see a bit of a doughnut hole in this picture but most of the time we can focus all or most of it out.
This is a picture of the reflector made for the Cree XPE XPG This gives a very smooth and concentrated hotspot.
New OPTICS Modules for XRE only
All of the modules end up being as close to standard length as possible The large die leds are much thicker and there is a small possibility that there will be a crack at the head and body. I keep all as short as possible so if there is a crack there is probably nothing that can be done.
All hosts are slightly different and one module may fit tight in a SF product and a bit loose in a FM Nite clone or an FM C but they will fit all. One may need to have the spring cut down to allow the head to close or a whole spring may be needed to keep the module from rattling. They also fit most Solarforce or any P60 style host
Most LED's are carried in Cool White, Neutral White, or Warm white when possible. They will be listed if in stock if not listed probably not in stock.
Battery configs listed are for any battery that falls into the range listed.
Potting is the filling of electronics cavity with thermal epoxy for heat management and shock protection. Copper tape is included with potting and both are included at no charge unless specified by member.
ALL MODULES ARE LEAD FREE, ALL SOLDER USED IS LEAD FREE
EMITTERS CARRIED
Seoul P7 $65 - 3.6v - 6volts ONLY /
1- 3 or 4 levels regulated /Cool White
__________________________________________________ _______________________
CREE LEDS
http://www.cree.com/products/xlamp.asp binning and tint informaiton (GREAT RESOURCE)
Cree XM-L $40
U2 flux bin 1A 6500k+ Cool White
T60 flux bin 3C 5000k daylight white
T50 flux Bin 4C 4300K neutral white
T40 flux bin 5B3 4000k neutral white
T40 flux bin 6A3 3500k Warm white
T30 flux bin E7 3000K Warm White
Direct drive
1 Level only (potting and tape included this model only)
works well in the 26650 Cooly's by Five Mega. Not made for continuous run.
________________________________________________________________________________________
1 level 2.2 amps 3.6-16 volts best for use with Multiple cells.
Available levels with memory (2.8-6 volts only) 3Amp stock
1 level Regulated
3 level Low / Med / High Regulated
3 level Low / Hi / Strobe Regulated
4 level Low low/ low / Med / High
6 volt Drivers are 3 amps stock and can be pushed at and
3.5 amps or even 4.2 amps but high should be used for shorter periods these do work well in the 26650 Cooly's by Five Mega.
and in
2P 18650 P60 M*g 1D by Fivemega There is no extra charge for these.
If you want to use continuously on high in most hosts please use 3 amps for better heat control and you will also get much better runtime.
Either Smooth OR Op reflectors available (extra reflectors not available at this time.)
Potting with copper tape is now included
XML TOWER MODULES $80 NEW!!!!
T6 flux 1A tint *ONLY EMITTER AVAILABLE AT THIS TIME*
Any of the above 6 volt max drivers listed under XML's plus ones listed below
1 level 4-16 volt 2.2 amp driver
Fits any of the surefire turbo heads such as KT1 / KT4 / KT5
Cree XP-G -$35 *mixture of throw and flood*
2.8-6 (levels are 100% / 40% / 5% )
5 level low / med / high/ SOS / Strobe with memory / 1.4 amp / 1/7 amp
5 level moonlight/ low low / low / med / high 1.5 amps
3 level low / med / high 2.8-6 volts with memory / 1.4 amp / 1.7 amp
1 level 2.8-6 volts
1 Level 4-14 volts / 1.5 amp
3 levels high / med/ low / 3.6-9 volts no memory / 1.4 amp
3 level 1v-4.2 volts for low voltage for A / AA lights
Flux Bins and tints that are available for XPG
Q23000K 7A3 (90 minimum CRI) NEW
Q4 2900k 8A4 tint
R4 4000k 5B3 tint /5B2
R4 5000k 3C tint
R5 5500k
- 2T tints (Cool White comparable to WH tint)
S2 6300k - 1T tints (coolwhite comparable to WF tint)
DUAL XPG (Linger Special)$45 Any of the above bins are possible / 3 level 2.8 amp 3.6-6 volts max *Floody* (levels available are same as XML)
DBS MODULES AVAILABLE ON REQUEST for most emitters / brass pill only no reflector/ same price as regular modules, potting is available on these also.
NICHIA
4500k 92CRI neutral ($35)
Driver Levels the same as the XPG's above
CREE XPC $30 (new)
Q5 WC tint available in 1 / 3 levels with memory in 1.4 or 1.7 amp
Cree XRE - XPE -$30 -
1.4 or 1.7 amp with memory
2.8 - 6 volts 3 level regulated high / med / low
2.8-6 volts 5 levels regulated - high / med / low / SOS/ strobe
3.6 -8.4V regulated @ 1.4 amps - 3 levels high / med/ low
XPE Good Throw
R2 or R3
available coolwhite / (Q3 5B)
neutral /warm tints
XPE Green , Red, Amber /Blue
XRE (Good Throw )
R2 flux WF tint
Q45B neutral
8E7 warm white
Green and Blue colors
Smooth OR OP reflectors are available
Optics are for XRE emitters only
/ Cool white , neutral white and warm whites.
8degree/ 60 degree.
$37 for module and 1 optic $40 with 2 optics
__________________________________________________ _________________________
Cree MCE $ 55 - GOOD FLOOD
1 - 3 or 5 level regulated
3.6 - 6 volts
Cool - M bin WD, WG
Cool - Nbin no tint supplied but pure white
Neutral - Kbin 5B tint
Warm bins JE5, JE6, KA3
OSRAM LEDS
Osram Diamond Dragon $40 - 3.6 -6 volts / 1/ 3/5 level
Ultra White /WARM WHITE/True Green / Red
Platinum Dragon - $40 Hyper-Red this is a true red no orange red. __________________________________________________ ___________________________
LUMINUS SST SERIES LEDS
Luminus SST-50 - $55 -
2.8 -6volts only *good throw with adequate spill*
direct drive
1 Level direct drive
Regulated with memory offered with same amperages as XML's listed above
1 level
3 level -- Low - Med - high
3 level -- low- high- strobe
4 level -- Low Low- low - med - high
Flux Bins are
6500K Cool White
(W65S-GJ102-WJ-G4 )
5700k (w57S-GJ201-WJ-H4 )
4500k (w45S-GJ400-WJ-P3 )
DBS MODULES AVAILABLE ON REQUEST *pill only*
Luminus SST -90 -$70 -
2.8 -6 volts only *Floody*
1 Levels direct drive
Also available in regulated drivers with memory of the same amperage drivers used with XML's above
6500 (W65S-WN-G3 )
5700k (W57S-WN-H4)
3000k warm 83CRI ( W30M-GK700-WK-U3 )
Green - Red
- Blue Colered SST90's also available
UV LEDS
Cree UV XL 7090 $45 (395nm)3.6 v-6volts /1 level
OSRAM IR LEDS
Osram Platinum Dragon IR $45 (850 940nm)-3.6v- 6 volts /1 level 2.8-6 volts
Quad Die 10watt IR great for night pictures
I also have
Seoul P4 - CW / Neut / warm 90 CRI
please PM for info on these
modules
I try to keep the above listed led's in stock, I also try to keep the newest and most popular bins and color temps from cool whites / neutrals / and warm white high CRI models.
Now as to levels in drivers , most of the time the levels are fixed and can't be changed. As new drivers become available the offerings will change on this page so please check it first. I often will have to change depending on what drivers I have available to me at the time so please check this page and I will update as needed.
Please specify what host and batts you are using when inquiring about a module or led. Just remember if you don't see it or don't understand something just write as I don't mind helping but check this page first. These are not try and buy!
Now that said the search button for the forum has a wealth of knowledge, much more than I can ever remember and usually with in days of a new led release runtimes and lumens are often posted please check the forum's search box as it is invaluable.
When ordering please post your order in this thread plus put details in Paypal notes of what emitter and tint ordered/ include choice of reflector / # of levels / check to see if shipping address is visible . Also please list CPF Nickname in paypal notes.
Shipping is 3 working days Although next day is not unusual Shipping confirmations are sent when mailed
Make sure your address in paypal is correct becuase that IS WHERE IT WILL BE SENT.
If you want it mailed to an alternate address
from the paypal address please state I want my parcel sent to an alternate address if this is not done I will think it is a duplicate address and will send to what is listed on PP.
MY Paypal info in biography or PM for it / I do not send confirmations that I received your paypal if properly addressed then I WILL receive it, you should be receiving a receipt from paypal when sent.
Shipping Conus is included 1st class,
Domestic Priority is $5 for up to 3 modules
International shipping is $5 for 1st class Int up to two modules , Priority Mail Int. is $15 up to 3 modules , express mail and more than 3 modules quoted.
Beam shots are posted below and new products will be posted below. Please send your beam shots and I will try to list when possible or create a link to them.
New offerings will be listed below as they become available.
D36 for M STYLE and M to C lights are (HERE)
IN NEED OF A HOST THEN HERE ARE SOME GREAT FORUM MEMBERS THAT CAN HELP
Here on BST get Five Mega hosts (Here) These are some of my favorites and the new coolys
On marketplace get Fivemega 18mm Bodies in 5 Sizes Here
Jason will take care of you.
For milling of maglites and general millwork Will Quiles is the master and can be found (HERE)
nailbender
North Carolina
Re: P60 modules -warm, neutral, cool white/XRE-XPE-XPG-S2-XML-U2 / P60 modules (part
Hi All this will be a NEWS SECTION where I will post NEW items and such.
I have started another section so there is not so much information a person has to parse. Most of the offereing are the same and of course the QUALITY will always be there.
I have a couple of new emitters I am working with and will post once I feel comfortable they will work as they should.
3/20/2012 - ?
I will be closed for the next few days as I have some minor surgery scheduled, hopefully I will be back online by the end of the week. All orders have been processed.
If one wants to order that is not a problem but shipping may be a day or two more than my usual 1-3 days. I have made up alot of the more common tints ( U2 / 3C / 4C ) and should ship close to ontime. Questions may take a day or two to answer until I become more mobile.
Thanks
Dave
4/7/2012 LOW POWER VAMPIRE DRIVERS
HI
OK Will Quiles has made some Very Low Voltage Drivers, these are for draining every last drop of voltage from old alkaline or NIMH batts. They will work up to 3 volts so you can use a 1XCR123 primary. You can read about it in his thread HERE at Will's Joule Thief thread , I have had many requests for so called vampire modules that would do just this run for long periods of time and drain every drop of juice left in the batts. Now these are not super duper bright lights but are certainly bright enough to walk around with and use in many other tasks. They make good emergency lights and everyone has old remote batts and toy batts.
I have tested these with a 3C daylight white XPG and a 3C XML and what I have found is that the XPG and XML are about the same brightness when running with a new 1XCR123 primary, the XPG will have a slightly better hotspot and the XML slightly more floody but basically the same brightness. I would say at 3 volts the brightness is slightly brighter than the LOW level on one of my stock XPG modules.
I also tested at 1.5 volts and the XPG was brighter than the XML but both could be used in a emergency lighting situation. I believe the reason the XPG is brighter is that the VF of the XPG is lower.
The way Will and I are working this at this time is if you want me to build your module go to his thread and buy the driver from him and have him send the drivers to me. The cost for me to build is the posted price on this thread for the emitter you want. If you choose a XPG then it will be $35 as posted, I am including potting for no upcharge on these modules. If you choose a XMl then it will be the standard $40. Shipping is included in the US as always.
As for emitters about any of the Cree emitters will work but if you looking for long lasting I think you will find that the lower VF emitters such as XPG or XPE will be brighter longer. This can be any of the tints that I stock and you can also use colors such as red
Pictures of the driver and module can be seen on post #41 of this thread
Thanks
Dave
4/16/2012
Hi all
A few of you have asked for the Nichia neutral 92CRI so I have ordered a few of the emitters. They are on backorder but there is no need to pre order as I am sure there will be enough. Once I get them I will post in the thread as I see no need to clutter the forum with a separate thread. They should price the same as a XPG module.
As always I am trying to keep what you all are looking for.
Thanks
Dave
4/21/2012
Nichia 4500k 92CRI emitters are now in stock and are priced the same as the XPG's
Thanks
write2dgray
Princeton, NJ
Nice work Dave, your selection has expanded nicely and I'm really enjoying the last 3-mode potted XM-L T5 flux 4C tint driven at 3A. Top quality - you're an asset to CPF and we wish you a painless/speedy recovery :).
Chris_Himself
I'll take:
XML U2 6400K tint
3A 1-mode regulated 2.8-6v
OP reflector
Potted w/ copper tape
$45
BIGLOU
I'll take a single mode (super duper bright) XML U2 1C Direct Drive 4.2 amps. SMO Reflector. No rush on the delivery and my prayers to a speedy recovery to one of CPFs Greats. Thanks Mr. Lemert!
PP $40 Payment Sent (Unique Transaction ID # 6R18444861059544L) for my 12th NB XML drop-in.
spc smith
PATRIOT NATION
Hope your recovering VERY quickly Dave! Thank you for the service youve offered to all of us serviceman and CPFer's=) Blessings be upon you:)
rewdee
Indonesia
hi, do you have a single mode for the XRE? does optic means a lens? will it fit a surefire 6p or solarforce body? thanks.
oal
Nailbender - Cree xpe-r3 3.6 -8.4V regulated 3 levels high / med/ low ( yes - memory) cool white pill for my DBE. please.
paypal sent
Croyde
:paypal:
XM-L T30 flux bin E7 3000K Warm White. Single level regulated, 2.8-6 volts, 2.8amps, orange peel reflector and with thermal potting and copper tape. International shipping required.
Tana
Bosnia & Herzegovina
Good luck with the surgery and fingers crossed for fast recovery...
yifu
Australia
Wish you a speedy recovery!
RCantor
KC, MO
I'm not Nailbender but yes, he does and yes, it does fit. These are great modules. An optic is sort of like a lens. It's more like a beam shaper. It takes the place of the reflector and causes the light to be thrown in a reasonably tight beam. I've been meaning to do comparative beamshots for ages. Maybe I'll have time this week...
Good luck with the surgery and get better soon!
nailbender
North Carolina
Hi All
Thanks for all the good wishes, it has taken me about twice as long for recovery as I was originally told but maybe that is because I have more than twice as many holes in me as I was told I would have :) Anyway I am back up sitting for longer periods and hope to get all the PM and posts answered by end of tomorrow.
I also hope to be back in the shop Tuesday, I am sure I will be a bit slower but it won't take long to catch up! I should be able to answer PM's and posts daily after today.
Sorry for any delays
Dave
Thanks to RCantor for answering the one post, as he said if you like the look of a surefire with a lens then you will like this but if you are looking at the lens to increase throw over a smooth reflector then you may be dissappointed. As he said it will smooth out some of the rings that are visible when wall hunting with a XRE in a smooth reflector and will keep the beam tight but it will not give better throw than a reflector will.
dandruff
singapore
Cree XML T60 3C, 2.8-6 volts, 3 level Low / Med / High Regulated, 2.8amps, OP Reflector, Potting with copper tape.
to fit Surefire 6PD with 2x CR123 primaries, and maybe a 18650 at some point in the near future.
Module + Potting + 1st Class international shipping = 45 + 5 + 5 = $55. Paypal sent!
I have also PM'ed you.
Thanks and speedy recovery!
rewdee
Indonesia
Hi, thanks for the prompt response. Hope you get well soon.
I was thinking about throw, but a nice tight beam is very tempting. Will give it a thought. thanks.
yifu
Australia
If you want throw, just ask Dave (Nailbender) to take off the reflector and just ship the 1.4A XR-E pill. Then screw it onto an Ahorton Aspheric P60 spacer kit available here
http://www.candlepowerforums.com/vb/showthread.php?308032-Ahorton-s-sales-(Lenses-headlamps-...)
This would get you about 5 times the throw of the TIR optic.
jak3All3n
Montréal
Hi Dave, hope you're feeling better, I'd like one of these:
XM-L $40
2.8-6 volts
3-mode L/M/H Regulated (3.5a on high)
Smooth reflector (unglued please)
Potted with tape $5
International Shipping $5
Total: $50
:paypal:
yifu
Australia
Got my 90 minimum CRI drop in! Nice tinit!
zilingz
Before few days I made ​​such a combination and must say that i am very satisfied. Using in L2P solarforce, the light have a nice bright beam and the spot has very nice projection and size of the led. Excellent thrower for my needs.
Status
