Hey guys!
I'm looking for a general purpose headlamp. 1AA or 2AA, multiple light intensity modes, floody light, and waterproof (rain as well as squirts from any direction). Also, the headlamp should be comfortable to use with glasses on (both, prescription and safety glasses).
I've been reading the forums and going to different websites of flashlight manufacturers, but I have not been able to find the best all around headlamp. A couple models that seem good are the Zebralight H51F (and H51Fw) and the Spark SD52-CW. But I'm sure that there must probably be even better options out there. Cool or neutral tint is fine with me as I seldom need to distinguish colors with precision, but I'd be willing to experiment with a warm tint if that doesn't considerably decrease the light intensity output.
Also, I've seen that several quality headlamps use what seems to be a silicone wrapper around the headlamp itself. Now, I have absolutely no experience with this kind of material, but wouldn't this "silicone rubber material" be prone to wear off quickly or perhaps even easily break?
_X__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
_X__Less than $50.
_X__Less than $100.
3) Format:
_X__I want a headlamp.
4) Flashlight-specific format/size:
_X__I don't know. 1AA or 2AA, something that doesn't get uncomfortable to wear in my forehead for several hours in a row.
5) Emitter/Light source:
_X__LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
_X__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
_X__I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today's most powerful lights)
_X__I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
_X__I want to navigate a dark room or read a map (0-10 lumens).
_X__I want to walk around an unlit rural area (50-150 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
_X__Less than 1 yard/meter (reading, other close work)
_X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_X__5-20 yards/meters (check out a noise in the backyard)
_X__30-50 yards/meters (I have a big backyard)
I'll probably spend most of the time using it at "arm distance" to "walking distance".
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
_X__90-120 minutes (Runtime is moderately important, but still not critical)
_X__3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
I'll probably need the longest runtimes on the lower modes (in the ballpark of 20 to 50 lumens), but the longer the runtimes the better. I know this is hard to accomplish with a 1AA or 2AA configuration.
_X__Very Important (Camping, Backpacking, Car Glove-box).
_X__Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
_X__I don't know.
_X__I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
_X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
_X__I don't know.
Eventually, I'm not in a hurry so I can wait for a while if there is something interesting about to be released.
Thank you in advance for all your advice and suggestions!
_X__Less than $50.
_X__Less than $100.
3) Format:
6) Manufacturer:
_X__I don't know.
_X__I don't know.
