RofisLight
Page 6 of 6 FirstFirst 123456
Results 151 to 171 of 171
Thread: Got Lucky - Right Place at the Right Time
  1. #151
    *Flashaholic* BVH's Avatar
    Sep 2004
    CentCalCoast
    Default Re: Got Lucky - Right Place at the Right Time
    That's a great practice. Definitely worth a try.
    WWII 60" Carbon Arc (Sold), 1.6KW NightSun, 1KW VSS-3A, .8KW TrakkaBeam, 600W M-134 Light, 500W X-500-14s, 500W Starburst, 500W A120b, 450 Watt AEG German Leopard 1 Tank Light, 300W Locators, Megaray, 150W Communicator, Maxabeam Gen3, Pichel 75W Mini-Novas
  2. #152
    Sep 2004
    CentCalCoast
    Got the MR rigged up tonight so that I could, with precision, test the beam maximum focus by shooting the Manufacturer's mechanically stopped focus, +1/16, +1/8", +3/16", +1/4", + 5/16" forward movement of the tube & lens. Now a couple of qualifiers. All shots are at F3.5 and 8 Sec. When cropping, I tried to be as close to the same for all but as you can see, I was not equal on all of them. I don't think that makes a significant difference. What I actually saw, was more dramatic than depicted. The moment I moved forward from MFG stop, it was apparent that the donut hole was developing. It is difficult to see the difference between mfg's stop and 1/16" but look closely at the size of the hotspot btw the two. The mfg's stop is smaller.
    MFG's max
    +1/16" forward
    +1/8" forward
    +3/16" forward
    +1/4" forward
    +5/16" Forward
    MFG's max (again)
  3. #153
    FRITZHID's Avatar
    Jun 2011
    Icelandic wastelands of Monico, WI
    well.... MB has that lens that compensates for the doughnut hole... maybe that could be used? JAT.
    if your not wearing a #12 welding screen than it ain't bright enough! "Hand-Sun H.I.D." 55w & 75w, Rocky 3w LED, Stanley 109 35w mod'd, Maxa-Beam Gen II, 55w hid/100w incan Vector Twin, 400w MH long arc, 100w MH mid arc. Amondotech n30, vss-3A.
  4. #154
    Sep 2004
    CentCalCoast
    Without having a collimating filter for my MB, I don't know the results of using it but what I don't understand is....You buy a MB for it's laser thin beam. If you want to flood it out a bit, use the de-focus feature. But you can do that to the point of having a donut hole. But now you can get rid of the donut hole with a filter. But why not just re-focus the beam instead of having to carry and use a filter?
  5. #155
    Sep 2004
    CentCalCoast
    Hurray! No more Magic Smoke escaping after a 20 minute run. I suspect it was the silicone sealant holding the silicone doughnut in-place and not the silicone doughnut itself. Actually, the sealant was probably to increase the amount of flash-over protection insulation beyond the doughnut because the doughnut is very thin at its' point of contact on the bulb versus its' nominal thickness of about 1/4".
  6. #156
    FRITZHID's Avatar
    Jun 2011
    Quote Originally Posted by BVH View Post
    well, MY guess would be able to have a larger spot w/out the donut.
  7. #157
    Sep 2004
    CentCalCoast
    I didn't mention that a while back, I was in the process of removing the front lens by removing the retention clip and then I set the light down to get a different grip. The lens fell forward striking another magnifying glass lens I had sitting on the bench and a small chip appeared. Big enough to be visible in the beam. No, it couldn't land on the carpeted bench top, it had to find the other piece of glass! I communicated with Leon at MR and asked how I go about buying a replacement. He came back saying that he would look around back in the shop to see if there was a used one sitting around. Same day he came back and said he had found one with a tiny chip on the edge that is covered by the retaining ring. He sent it to me for nothing, including postage!! And when it got here, I was extremely please to find it was AR coated! How about that for customer service!!
  8. #158
    Sep 2004
    CentCalCoast
    Maybe the only On-Board Power Megaray in existence?
    26.4V/4.2AH LiFeP04 pack
    Self machined Aluminum mounts and end caps
    Carbon Fiber Tube
    On Board battery negates need for Red Buret!
    MR draws about 8.5 to 9 Amps at 26V so I expect to get maybe 20 - 25 minutes of run time.
    Back end power entry end cap
    Back end cap and rear battery support ring
    Back end support ring flat mounting surface and screw
    Front end cap
    Finished
  9. #159
    Aug 2004
    Sydney, Australia
    That looks really nice, BVH. Lovely combination of materials. That lathe is a handy thing!!
    Thanks God you could lose the beret (quite fetching, though, on the right person....)
    What about a belt mount??
    Kind Regards
    David
  10. #160
    Flashaholic ShortArc's Avatar
    Dec 2005
    Massachusetts
    Nice work Bob!
    But it's round...how can you set it down
    PS. Got the 125W version, now to find the time to compare it to the 175W one.
  11. #161
    Dec 2005
    Massachusetts
    Here is a pic of the Lead Acid Bat pack it came with.
  12. #162
    Sep 2004
    CentCalCoast
    Now That's what I call HEAVY duty!
    One thing I did not plan on in deciding to do this project, was that the MR has a full-time parasitic current draw of about 40 mAh. I found this out while finishing the electrical connections and observing a tiny spark when connecting the fuse. So, while it's not difficult to remove the setscrew and front end cap for charging, it will require an additional R&Rs for connection and disconnection of the electrical when using the light. The draw will empty the pack in 4 days.
    While I did not think that the mod was all that practical, I thought it worth the effort considering I wanted some experience on the lathe and mill and that I have another MR that is stock. This one may go back to stock. But then again, I hardly use them so what's a few extra minutes going to cost?
  13. #163
    Dec 2005
    Massachusetts
    WOW a 40mA draw. That is alot. Thank you for this discovery.
  14. #164
    Flashaholic* Lips's Avatar
    Mar 2005
    Louisiana - USA
    Very Cool. I'm jealous!
    Bet soldiers would like setup over heavy backpack at times.
  15. #165
    What do mean the lights are from south africa?
  16. #166
    Sep 2004
    CentCalCoast
    Quote Originally Posted by stephan van straaten View Post
    Night Vision Optics/Megaray: Somerset House I 11 York Street I Randburg I Johannesburg I 2194 I South Africa
  17. #167
    Flashaholic japudjuha's Avatar
    Aug 2012
    South Australia
    BVH
    In your first post you mentioned a portable 28v power supply.
    Quote:
    "What the heck – a new 80 Watt Maxabeam is $2,300 and I can run this light on my 28 Volt portable power supply so a working light would cost me about $1,850 with shipping."
    May I ask about the specifics of this PS.
    I am looking for any options that will work for powering a Q4559X application.
    Thanks
    James
  18. #168
    Sep 2004
    CentCalCoast
    PM sent.
  19. #169
    Sep 2004
    CentCalCoast
    A free MegaRay charger over on MarketPlace Giveaways.
  20. #170
    Flashaholic* bshanahan14rulz's Avatar
    Jan 2009
    Tennessee
    Very nice of you, nice kits too :-)
    I did want to comment and say that tube looks awesome!
  21. #171
    Flashaholic holylight's Avatar
    Feb 2013
    Germany
    Default Got Lucky - Right Place at the Right Time
    When I get my hands on these, my wife will use it it to knock my head.....
    lights: saber1a, v11r, sc52, sc600ii, ea4, tn31, archer1a.
