Bronte Flashlight
Results 1 to 13 of 13
Thread: Lithonia LED Dusk to Dawn Light
    Default Lithonia LED Dusk to Dawn Light
    I've wanted one of these lights for awhile and finally bought one this past week. I had a motion light above the garage that would turn on at dusk and stay at 50% until it sensed motion and then it would kick onto 100%. The biggest problem I had with that light is the power draw. 75 watts at 50% and 150 watts at 100%. The motion sensor was wigging out as well and the light started turning off when it sensed motion (when I was wanting light).
    Anyways I bit the bullet on the Lithonia from Home Depot and I'm pretty disappointed. I do have to search here to see if others have reviewed it but the light is extremely bright and very cold in color. If anything it gives LED's a bad name. It doesn't match any other lighting I have at the house and is so cold it looks industrial.
    Here are some pics.
    The light:
    On the house
    Bad cell phone pic but you can see how bright it is and how it doesn't match my homemade eave lights or my LED Malibu yard lights. The Lithonia is so bright I have to point it straight down so I don't blind the neighbors. I just don't like the color or lighting up the front of my garage like that.
    Default Re: Lithonia LED Dusk to Dawn Light
    This is my front entry way for comparison. They are crees at about 3300k. Nice and warm and not intrusive.
    This is also a cell phone pic in the rain but it shows the Malibu lights and the old motion light at 50%. I liked this look much more.
    I'm not looking to do a review or anything but point out what I don't like and hopefully get some advise.
    Is this Home Depot light similar to everything else out there? I'm looking for just a dusk to dawn and not too bright. I'd prefer to only light the driveway where the vehicle is parked. No spot light or anything. I've thought about modding this current light but it's a bit too expensive to just gut and I don't really have the time to order and build something.
    Here we go. I like the specs on this one. 700 lumens compared to the 1600 on the Home Depot one. It also states color and it's where I need it.
    http://www.dealextreme.com/p/10w-330...-85-265v-96061
    I know these have been posted about here but I can't find them. Do they go by a certain name? Any consensus on these?
    Dec 2003
    Indianapolis
    I agree - mixed color temp sources look nasty. Not that you asked my opinion, but if it were me, I'd loose the entire "floodlight aspect" of the light over your garage. The rest of your outdoor lighting is so subtle and easy on the eyes - IMO, small amounts of light from numerous sources spread around the area look so much better. Maybe a couple of wall mount fixtures on either side of the GD, and some type of fixture with a shade directing light down over the door?
    BTW - I really like the uplights under your trees - I'm planning something similar...
    Jim
    I agree on the small amounts of light. I like the idea of the sides of the garage door but it's a big project. The high peak is something I have to contend with. A flood light was up there when we moved in but it only worked half the time. I replaced it with a flood with bulbs that have a G8 base and the draw kills me.
    My approach was to take these bulbs Ebay item 170811866667,
    rewire this fixture to MR16 base:
    http://www.homedepot.com/h_d1/N-25ec...&storeId=10051
    and run it to my low voltage transformer.
    $40 a fixture and 13 watts. Seems plenty bright on each side of the house to deter intruders
    USA
    Swap a couple LEDs on the Lithonia fixture with some really warm 2700k LEDs(XML's or XPG's). Lithonia states that their fixture is 5364k-5700k depending on what datasheet you read
    http://www.lithonia.com/commercial/D...loodlight.html
    http://www.acuitybrandslighting.com/...heets/LF3P.pdf
    Ebay has those warmwhite 10w fixtures for $20 or less. Shop around before buying at dealextreme.
    Quote Originally Posted by fmzip View Post
    So I poked around a bunch at Home Depot after I returned the light. I found the light housing you linked and I like it. It's actually the base version of what the LED one replaced. The one I have has motion and dusk to dawn though. I don't like or want the motion so I like your fixture. I need it to be dusk to dawn though and I found a photo eye that will work great.
    Two things came up though that kept me from buying everything. For one the light fixture uses bulbs that have a G8 base. While similar to the MR16 it is different. The G8 pins are about twice the thickness and spread farther apart. The other thing is the drop in LED fixtures. All seem to be directional where are the stock halogen bulb utilizes the reflector in the housing. The drop ins won't use them at all. I looked at several different brands, some with 3 emitters and some with only 1. My concern here is that the light will be very spotty.
    How did you get the MR16 in the G8 base? I tried spreading the pins but they were solid and didn't want to crack the bulb housing. I also want this fixture to be safe. Last thing I want to worry about is a garage fire.
    Quote Originally Posted by deadrx7conv View Post
    http://www.lithonia.com/commercial/Dusk-to-Dawn 3-Head LED Floodlight.html
    I thought about it but the light was already $145 and I didn't want to put any more into it.
    I have cree eave lights and under cabinet lights in my kitchen and love them. They are all custom and run off of Meanwell drivers and I was thinking about building a light for the garage but don't have a ton of time as we have a newborn in the house. I know it would be cheaper than the HD light but it would also require some R&D (time and money).
    Quote Originally Posted by Mike M View Post
    I didn't, I just rewired the fixture to MR16 bases. It was an easy swap.
    Search for Ebay Item number: 300635656147
    Unenlightened
    Jun 2012
    Have you purchased any other products from Lithonia?
    I did replace my halogen light. I ended up with a 10 watt led flood from the internet. I wanted LED as I knew there was something out there that would give me the output and color I was out there. Energy savings were important as well.
    The light has a lot of flood, much more than the two head halogen it replaced. As such I have it angled down so there is some garage door frame shadowing but because the light isn't overly bright I don't mind.
    My original plan was to wire in a photoeye to make the light dusk to dawn. I tried 2 different types of sensors and neither worked with this light. As such I replaced the switch that controls the light with a timer switch.
    In the end I'm really happy with the light. Cost for the light was $35 shipped from China. It's been on every night for the past 3-4 weeks and it's going strong.
    Quote Originally Posted by Lightbox100 View Post
    Lithonia is a large and well established manufacturer of various types of lighting equipment. I have several Lithonia items.
