Malkoff
Page 11 of 20 FirstFirst ... 456789101112131415161718 ... LastLast
Results 301 to 330 of 572
Thread: Jetbeam tcr 01 is out
  1. #301
    Default Re: Jetbeam tcr 01 is out
    So I used a watt meter to test the light. I used a hot off the charger Ultrafire 16340 that started off at 4.18v. When blasting it to max, the current draw was 1.8A at 3.6v. That's almost 6.5W draw at the battery. Then as the loaded voltage dropped to 3.3v, the current draw was about 1.3A, that's only 4.3W at the battery. At 3.1v, 0.9A, at 3.0v, 0.85A. Then at about 2.45v, the light went into rapid flashing and shut down. The supposedly protected Ultrafire 16340 did not cut off voltage soon enough before the light's rapid flashing. I wish the battery would cutoff at no less than 2.5v though. The bright side is, I manage to get over 700mah out of the battery before it dropped below 3.0v, pretty much driving the battery starting at 1.8A all the way down to 0.85A at 3.0v.
    Does that mean this light is direct drive?
    I am going to try to hook up a 18650 later to see.
  2. #302
    Flashaholic* MY's Avatar
    Apr 2001
    Thunder Bay, Ontario
    Just received three lights today: TCR1, RRT01, and SWM Ti+. I am sad to say that I am not impressed with the TCR1 and will be sending it back. The main concern is the control ring is loose, wiggles up and down and sideways. If the ring is in a detent and is pushed up on one side, it will almost jam and need extra effort to release. The tint is too green and the finish has scratch marks. I really don't care about the scratches as that will happen anyways. The ring on the RRT01 has just a slight amount of wiggle room but is gritty - I can live with it though. On the other hand, other than the terrible switch on the Ti+, I think the SWM quality is greater than the jet beams. The Ti+ control ring is just about perfect in feel and action and the tint is white. So two out of three but unfortunately the one that I was most excited by was the TCR1. Not sure if I should exchange for another or wait for the Niteye 10Ti which is an improved TCR1 with OP reflector, U2 bin, cooling fins, and multiple detents on the control ring. (Niteye makes the TCR1).
    Regards
    Be Mindful of the Moment
  3. #303
    Quote Originally Posted by MY View Post
    Regards
    You might've gotten a dud. Or just have really high standards. The control ring on my TCR1 isn't loose at all. However, I have noticed that with both it and the RRT-01 to get maximum control turning the ring I need to hold the light in my palm and use both my thumb and index finger on opposite sides of the ring to turn it. Trying to turn the ring with just 1 finger doesn't work. I could see how if you're used to the extremely loose ring of a V10R XM-L and are used to turning it with 1 finger, you would not be happy with the Jetbeams which require 2 fingers.
  4. #304
    I love this light, and have purchased both the HA & TI versions. I never seriously considered the V11 as it doesn't seem like a step forward from the V10.
  5. #305
    Flashaholic Theatre Booth Guy's Avatar
    Jan 2006
    Michigan, USA
    Quote Originally Posted by senna94 View Post
    I hate that the clip rubs against the head instead of resting against the body so I didn't install it. However,I did install the screws for anti roll purposes and to keep dust out of the threads. The allen wrench included is crap but a Wiha 267 T6 X 40 or equivalent works perfectly on these screws.
    +1 about the included wrench. it seems undersize and spun in one of my screws before it was really tight. Monday will be a trip to the local fancy fastener store for some torx drive screws!
    Brian
    After getting an HDS, other flashlights seem much less relevant (Except for some of the really special lights found on CPF!)
    When things are really dark, a dim light for a long time is much better than a blinding light for a short time.
  6. #306
    Banned
    Jul 2009
    Maryland, Near DC, USA
    MY, I suppose everyone is entitled to their opinions. It's odd that you find the TC-R1 to be lacking in quality compared to the SWM V10R Ti+, since that's the opposite of what most people have seen thus far. I suppose you're just the lucky guy who got a marginal TC-R1 and an above-average Ti+. Do you feel special?
    Anyway, it's better for the control ring to be slightly loose than slightly tight, because slightly loose will allow grit to work its way out eventually, whereas slightly tight would be unusable. I can't explain the tint, though; everyone's eyes work a little differently. I suggest using the light for a few days, though, instead of just comparing it to the SWM. You may decide that the comparative differences are only noticeable when you're comparing the two lights to each other instead of using them for their intended purpose.
  7. #307
    Banned
    Jul 2009
    Quote Originally Posted by aau007 View Post
    Try it with an AW protected cell. AW's protection circuits should work better.
    I don't think the light is direct-drive. Rather, I think the light is designed to achieve maximum brightness using the most powerful cell it can hold, fully-charged, and output starts drooping as the cell wears down. That is different from direct-drive because direct-drive doesn't control the voltage going to the emitter, and there would be a noticeable change in tint between an emitter being driven by a 3V primary vs. a 4.2V rechargeable battery. I just compared the two TC-R1s I have, and while there is a difference in brightness between primaries and rechargeables, there isn't a difference in tint.
  8. #308
    Mar 2011
    Los Angeles
    I'm sorry to hear that some people feel let down by the TCR1. I'm very happy with mine. It's quite a bit thicker than my T1A, though the fact that it can handle 18350s without an expensive mod partially makes up for it.
    I'm surprised that Jetbeam went with a smooth reflector, as a flashlight this small is probably not going to be anybody's go-to when they need a real throwy light. As far as "real world" use, this is a great indoor light, which is exactly where that ringy beam is going to be the most visible. That's my only real gripe with the light, though.
    The low-low is sort of ridiculous, but really pushes the idea of "infinitely variable" control. You can actually get it dim enough that the only evidence that it is on is that the reflector stands out in a pitch black room.
    I like mine so much, that I considered getting another one. Looking at the Niteye 10Ti, it seems that there might not be any real rush, as these might not be so limited after all.
  9. #309
    Quote Originally Posted by fyrstormer View Post
    So I tapped a 800mah high drain LiPo battery to the light. After about 5 seconds, my watt meter shows 2.25A at 3.75v. That's about 8.4W at the battery.
    Not sure if "direct drive" is the right term. My observations with the watt meter is that output drops when the voltage under load starts dropping. Different battery types also exihibit different A vs V behavior. May be "not regulated" is the right term? What do you call it when the output varys when battery amp/voltage under load changes and the setting at light is the same (max).
  10. #310
    Flashaholic OneBigDay's Avatar
    Nov 2009
    Minneapolis, MN
    Quote Originally Posted by Z-Tab View Post
    ...Looking at the Niteye 10Ti, it seems that there might not be any real rush, as these might not be so limited after all.
    I just saw this too. A lot of copying going on but this is really blatant. If the quality is in the same category it takes the edge off the LE quality of the Jetbeam. On the other hand if the Niteye comes with a OP reflector a lot of people might jump ship.
  11. #311
    Nov 2009
    Minneapolis, MN
    Duplicate Post
  12. #312
    Quote Originally Posted by OneBigDay View Post
    I just saw this too. A lot of copying going on but this is really blatant. If the quality is in the same category it takes the edge off the LE quality of the Jetbeam. On the other hand if the Niteye comes with a OP reflector a lot of people might jump ship on the Jetbeam.
    It was explained that a single designer licensed the design to both Jetbeam and Nighteyes. Both are fully licensed to sell the design. As such, the Nighteyes isn't really a "blatant copy" of the Jetbeam.
    The Nighteyes looks like an interesting light. Compared to the Jetbeam it has
    * U2 emitter for higher max output. (someone on the forum measured the RRT-01 at 542 lumens on IMR 18350. Compared to over 640 lumens for the Nighteyes EYE 10).
    * Orange peel reflector
    * extra detentes midway through the ring travel. This might be good or bad.
    * extra hidden strobe mode.
  13. #313
    The only thing holding me from the Niteyes, is that personally I find the Jetbeams much more attractively styled.
    One detente on the standby is really all that is needed; they didn't need to have a turbo detente, because it is a chore twisting the ring out of any detente.
    Personally, I wouldn't want any more detentes in the middle...
  14. #314
    Nov 2009
    Minneapolis, MN
    I did see and read the review/post from subwoofer that explained the design was licensed to more than one shop. It's not that I don't believe it but it doesn't make much sense from Jetbeam's perspective. Why market a Ti "Limited Edition" light when you know the shop next door is going to mass produce essentially the identical light at roughly the same time. It makes the consumer feel like somebody is pulling your chain.
    All semantics aside about what one would consider a copy...
    The OP reflector alone is enough to consider one over the other. I agree with the previous posters who have said there is no good reason for a SMO reflector on an EDC type light like this. OP is the way to go. If you need real throw you'd reach for a different light.
    Any way you slice it up this is an interesting game to watch between the tcr01, v10rTi+, and now at the edge of the frey, the Niteye 10Ti.
  15. #315
    The circuit of TCR01 (RRT01) should be same as RRT0.
    RRT0 was proved to be direct drive using RCR123A with voltage higher than 3.8V.
    http://www.candlepowerforums.com/vb/...=1#post3701869
  16. #316
    Quote Originally Posted by peterharvey73 View Post
    I agree on the detentes. They should have skipped the detente at max power. All they really needed was the detente at minimum to prevent the light turning on accidentally.
  17. #317
    Banned
    Jul 2009
    Quote Originally Posted by Fireclaw18 View Post
    You're not going to get 100 more lumens from a higher-binned XM-L. Niteye is doing something to drive the emitter harder too. Longevity is questionable, though it's not in any of these companies' best interests to make products that will last decades on purpose.
  18. #318
    Banned
    Jul 2009
    Quote Originally Posted by juplin View Post
    The RRT-01/TC-R1 is over a year newer than the RRT-0/TC-R2. It's possible the circuit is the same, but there's no guarantee. For one, when I expose my TC-R1 to an external magnetic field it simply shuts off instead of going crazy like my TC-R2 does.
  19. #319
    I agree. The extra 100 lumens, if accurate, isn't just from going to a higher bin emitter. It would mean that Nighteye is driving the emitter harder, which could mean heat could be more of an issue and battery life would be reduced.
  20. #320
    Banned
    Jul 2009
    That's a good question. I suppose "direct drive" is a form of "unregulated", where "unregulated" means that neither the voltage nor the amperage is held at a specific value, but "direct-drive" specifically means the power coming out of the battery goes straight into the emitter without any control at all.
    I don't think that's what's happening; I think the XM-L emitter just has such low resistance due to its size that it can tolerate a massive amount of amperage at its rated input voltage, and only a very powerful battery can deliver it for more than a few seconds. Unless the voltage drop across the emitter is higher than Cree rated it for, it's not being direct-driven.
  21. #321
    *Flashaholic* kaichu dento's Avatar
    Apr 2008
    大和/Alyeska
    Lots of great points in your post and it's enjoyable reading about them while I wait for mine as it gives me plenty of food for thought before actually laying hands on one. One problem I face at present is that daylight is getting progressively shorter and if mine doesn't get here soon I may have to test it in the closet.
    Since you've compared the TCR-1 with the T1A, I assume the TCR-1 is easier to hold without slippage?
    I also wish they'd gone with an OP reflector, which has essentially become the standard anymore, but I'm already planning on an Arc6 reflector, which Fyrestormer has verified to be and easy swap with very little work.
    The super low level is really what I've been hoping to see from all lights with a sweeping UI, as there is no problem in simply running right past the levels felt to be too low, but for those of us who have real problems with lights that only go as low as the Clicky, V10R or worse yet, Haiku, the super low level is what really pushed me to buy my first new light in a while. The Haiku belongs in comparison the least, since it doesn't have a sweep interface, but the low on it makes it almost impossible to use in mid-winter for a great many of my tasks, while the TCR-1 should prove a blessing.
    I rushed to buy one because of the limited availability like you, but am now pretty curious about the soon to come Nighteye product.
    *The higher output is probably not that big a deal, as an extra 100lumens when you're already over 500 is not going to be nearly as noticeable as the difference between a 100 and 200lumen light.
    *Orange peel is good!
    *Don't know how I feel about the extra detents until trying one, but while I like them on a light with set points, they may prove to be annoying or useless, as others have pointed out.
    *If the hidden strobe is truly hidden then no harm, but I don't want to see it come on just because I turned the ring too far.
    Marduke - Solitaire...I've seen matches which are brighter AND have a longer runtime. 光陰矢の如し
  22. #322
    Flashaholic* senna94's Avatar
    Dec 2005
    Houston, Texas
    I did a search and can't find any info on the Niteeye. Can someone post a link to info on this light?
    "The Constitution says promote the the general welfare not provide welfare." -Allen West-
    To a democrat freedom means freedom from responsibility.
  23. #323
    Didn't see anything on a ti version, but here's the manufacturer's product page on the aluminum version...
    http://www.niteyelight.com/product/?type=detail&id=58
  24. #324
    Mar 2011
    Los Angeles
    Look familiar? Link (in Chinese). That's the only site that I've found with any info at all.
  25. #325
    Mar 2011
    Los Angeles
    Quote Originally Posted by kaichu dento View Post
    It is definitely less slippery and much easier to operate one-handed.
  26. #326
    Banned
    Jul 2009
    Wow. Really? Oh well.
  27. #327
    Flashaholic* Samy's Avatar
    May 2011
    Australia
    Haha that's funny. Twins?
  28. #328
    sadly no, the nite eye has a u2 and OP reflector...
  29. #329
    Banned
    Jul 2009
    Don't worry about the bin, petr. It won't make enough of a difference for anyone to notice. Also, newer bins are usually less-predictable in regards to quality; better to stick with a slightly older bin in a high-quality light, to make sure there's less for people to complain about.
  30. #330
    Banned
    Jul 2009
    I bought a couple of Oveready's 18mm-to-16mm battery adaptors, and it works perfectly in the TC-R1. I wrapped mine with a couple layers of clear tape for an extra-snug fit inside the battery tube, but it didn't really need it. Great accessory for someone (like me) who intends to use 16340s or CR123s.
