Well almost two months, but I'm finished with my first mod!
I used DX (part of the reason why it took me so long) and got an XR-E P4 LED (SKU 4877) along with a regulated driver (SKU 25518) based on the AMC7135.
Here is the head after I finished:
The process:
First of all, sorry I didn't take any process pictures. I started off and just kept going. The whole process took maybe an hour and a half.
- Removed retaining ring by drilling one of the relief notches (holes in ring in above pic), hand-driving a screw into the notch, and pulling it out with pliers. This probably isn't the most delicate method, but it worked fine.
- De-soldered the nine existing 5mm LEDs. I decided it would be easiest if I could make use of the circuit board, as it was the correct size for the housing.
- I cut the bottom out of the plastic "cup" that held the 9 LEDs in place. This made room for the driver to sit under the new LED. Again, I apologize for a lack of pictures.
- I wanted the driver to be flush against the existing circuit board, so the easiest method was to drill a hole in the existing board and solder a spring directly to the driver's positive contact area. As you can see, the new spring passes through the old circuit board. Next I soldered a small wire from the driver's negative contact to the old circuit board.
- Lastly, I used hot melt glue (I realize this is a bad idea) to hold everything in place and I soldered the wires from the driver to the LED star.
The good:
- It works! Everything went smoothly (unusual for me) and it is an improvement over the unmodified version!
- The new LED star and driver fit well in the housing. I had no problems putting everything back together.
The bad:
- Hot-melt glue is not a good thing inside of a flashlight. I knew this, but I just wanted to get it to light up. It did, so I'm happy and not too concerned about the longevity of this mod.
- I made no attempt at heatsinking. I realize this may be a problem down the line.
- The LED tint seems a little purple. I don't recall noticing this the first time I used it. Is it possible that the purple tint is a result of heat damage?
The surprising:
- Five modes! DX didn't mention anything about the driver having multiple modes. It goes medium, low, high, disco (strobe) and SOS. I would rather go without the last two. Oh well.
- I've never used a mule flashlight, I.E. all flood. Wow!
Here it is. Note the hot melt glue holding everything in place. The LED star is actually centered pretty well though.
Beamshots coming in a few hours when it gets dark out.
