RMSK, Inc.
Results 1 to 21 of 21
Thread: New Olight X6 Marauder
    Oct 2009
    Oxford, CT
    Default New Olight X6 Marauder
    http://www.olightworld.com/en/produc...178&CateId=101
    Looks like a killer light. And you get to leave the battery pack on the ground. 5000 Lumen and 102400 Lux. Not bad throw but it should have crazy flood. Like a TK70/Hellfighter steroid induced baby.
    Oct 2009
    Oxford, CT
    Default Re: New Olight X6 Marauder
    I remember this being mentioned months ago. I was on the olight website recently and it wasn't there. Went on today to double check something and there it was.
    Oct 2009
    Oxford, CT
    Oops, thats what I get for watching tv and posting. Meant to post this in LED flashlights not LED. Can it be moved? Thanks.
    Dec 2007
    USA
    I think that if Cree introduces a LED that uses the 'xm' package, but uses the same process/design as the new xt-e, say 3mm^2 size and capable of 1,500 initial emitter lumens, and costs less too, the xm-l just became obsolete.
    One could take 5 of these, put out 10% more light than this, and have superior throw.
    6.5K diving light, 5K cool-white, 4K neutral-white, 3K warm-white, 2.7K extra warm-white
    I'm a little surprised their is not more interest in this light. Am I missing something? Looks like great form factor and tons of spill and throw.
    Quote Originally Posted by sledhead View Post
    So am I. It's advertised on a number dealers sites now, yet very few posts about it. Perhaps it's the price?
    Loyalty above all else, except Honour
    Might be the tethered battery pack that is off putting.
    Oct 2009
    Oxford, CT
    Default
    I dont think the price is that bad considering what you get from SF for just a bit less.
    I like that you dont have to hold the battery if it isnt necessary, makes it much lighter. And you can plug this thing into an outlet.
    Flashaholic* tx101's Avatar
    May 2008
    London UK
    The deal breaker for me on this light is the battery pack. What happens if the pack dies ?
    I would have jumped on this if the battery pack had user replaceable cells
    Oct 2009
    Oxford, CT
    Default
    Quote Originally Posted by tx101 View Post
    +1 That is a bit dissapointing. They did the same thing on their SR90. But that pack is just 6 18650 IIRC. They still charge ~90$ for a new pack though. I'd rather have that worth in 18650s. At lest I can use them elsewhere as thats not a light that gets used often.
    The battery pack is a plus for me - looks like a great clip, should make the light a breeze to handle. Being able to run this light on 12 volts should make the battery issue a mute point. Just had my Mac's EDC XML out, lights up and throws tons. Can't imagine 6 of them. Looking forward to the 1st review.
    What happens if the battery pack dies? Ummm you replace it? The battery pack is easily unplugged, so I don't see the problem. IIRC they went this way because a pack with 6 or whatever 18650's wouldn't have the same runtime.
    The only thing holding me back is my $70 HID... It only does about 3500 lumens but would out throw this and with the makeshift press'n'seal defuser puts out enough light for closer range. So I'm not sure if I need.. well OK I don't need it, but want it, enough.
    But then here's where the tethered battery is an advantage. This light is lighter than my HID, can run off my car or goal zero battery, or a second battery which surely will be an accessory at some stage.
    And here you go:
    Olight X6 Marauder (6x XM-L, Rechargeable) Review: RUNTIMES, BEAMSHOTS, VIDEO + more!
    Full list of all my reviews: flashlightreviews.ca. Latest hobby: whiskyanalysis.com. New: Selfbuilt's Summer Sale!
    Aug 2008
    Ohio
    I would love to see how the X6 compares to the Trustfire TR-J18 that has seven Cree XML's and is powered by three 26650 batteries.
    Oh yeah, and it only costs $75.00.
    Quote Originally Posted by BullsEyeLantern View Post
    The battery pack can be attached to the light if you don't want to clip it on your belt. Insulator bushings should be used to help with the heat issues.
    I think you saved me some money... it seems it drops to 3500 lumens almost straight away? So my $70 HID out throws it and has the same output? Ok it can't strobe or run at lower output but I'd be getting this for the higher output anyway... hmmmmm...
    Quote Originally Posted by PayBack View Post
    Depends on ambient cooling. In a warm environment indoors with no cooling, mine thermal-regulated down to a stabilized ~3500 estimated lumens, but it took nearly 20 mins to do so. I suspect in most outdoor environments where this is at least some breeze (or you are carrying it), it should stay >4500 lumens for the full run.
    But yes, these lumen ratings are consistent with ~35-50W HIDs in terms of overall output.
    Stop trying to talk me into it!! I know that's what you're doing.... I never suspected you were one of the voices I hear telling me to buy lights, but it's all starting to make sense! Buy it PB, Buy it... get out of my head!
    As an aside, thanks for all the reviews, output comparison graphs and alternating beamshot gifs. Between you and goingprepared's 100 yard tree comparisons there should be no surprises... which is why I'm likely to pass on the TM11 and go for an X10 on my "impress the uniforms Police Ride-Along" For an "older" light the X10 stands up well at 100+ yards compared to a 3 celled Tiny Monster.
    Hardly - just wanted to make sure readers of this thread knew what to expect in practical use (i.e., "almost straight away" is more like over 20 mins, and only in the worst case scenario). I'm glad you find the detailed reviews useful, but I know it's also a lot of info for people to wade through, so just wanted to make sure passer-bys here knew the gist of the review.
    Glad the reviews were helpful in making a decision. Like many ~700-800 lumen XM-L lights, the X10 does a very serviceable job lighting up ~100 yards. That may not really show up in the photos, since it is hard to get a camera setting that accurately matches what the eye sees.
    Sorry the first part of my post was a poor attempt at humor I won't give up my day job!
    No worries, I knew what you meant.
