Supbeam Light
Results 1 to 17 of 17
Thread: Where can I buy Cree XT-E royal blue LEDs, preferably XTEARY-00-0000-000000N04?
    Default Where can I buy Cree XT-E royal blue LEDs, preferably XTEARY-00-0000-000000N04?
    Any ideas where I can find/buy Cree XT-E royal blue LEDs, preferably XTEARY-00-0000-000000N04, on starboards (MCPCB's)?
    I searched the "usual suspects" Mouser, Farnell, Digikey, etc., but they only seem to have the surface mount versions, no starboards, and not the N04 bin (D36-D37=450nm-455nm and 550-575mW).
    Actually the only source for these LEDs on starboards I could find is here: http://www.led-tech.de/en/High-Power...5_120_184.html
    But the values displayed for wavelength, luminous flux, voltage etc. on this web page are all wrong, the correct values are:
    Manufacturer code of this reel is XTEARY-0-D46-330-F0-0001
    Wavelength range is D46 = 455.0 nm- 457.5nm
    Radiant Flux 330 corresponds to 525mW – 550mW
    Voltage range is F0 = 2.75V-3.0V
    Thanks a lot for any hints!
    Mar 2011
    Slovenia
    Default Re: Where can I buy Cree XT-E royal blue LEDs, preferably XTEARY-00-0000-000000N04?
    Cutter?
    Quote Originally Posted by Toaster79 View Post
    Cutter?
    Do you mean http://www.cutter.com.au/products.php?cat=Cree+XTE ?
    Nope.
    No XTEARY-00-0000-000000N04, they only have ...L0 and ...L07.
    Thread Killer Illum's Avatar
    Apr 2006
    Central Florida, USA
    Csshih has them on his website:
    https://illuminationsupply.com/cree-...34474bd33d874e
    Blue 10mm Star MCPCB
    unknown bin though, that you'll have to PM him
    Can't find a runtime for an old light? try the RUNTIME INDEX
    DEFCON 4, always...
    Apr 2006
    DEFCON 4, always...
    Quote Originally Posted by Illum View Post
    Craig Shih has them on his website:
    I just did; thanks a lot for the hint!
    Last bunch of XT-E's I ordered from RapidLED tested at exactly 451-452nm on my spectrometer, and they've been consistent. Not sure what flux they were.....
    Sep 2010
    Niagara Falls ON. Canada
    Digikey, Newark also has them.
    Mar 2011
    Slovenia
    http://www.led-tech.de/de/High-Power...c_120_184.html
    edit: missed the link in the first post :S
    Connecticut
    If you find the LED's and boards i an re-flow them for you. I've done this hundreds of times with my own LED's
    Quote Originally Posted by Optical Inferno View Post
    Do you have a link?
    I could not find this bin as a starboard in either shop.
    Thanks a lot!
    Quote Originally Posted by mds82 View Post
    Thanks a lot for the offer!
    I will consider that, as a last resort! :-)
    Quote Originally Posted by blasterman View Post
    Thanks a lot for the hint with "RapidLED"!
    I didn't know them and I'll check them out ASAP!
    Enlightened ledstein's Avatar
    Feb 2009
    Europe
    Thanks a lot, but this is the L01 bin, not the N04 bin I am looking for.
    Hi guys,
    thanks a lot for all your help!
    I ended up using the LEDs from Craig Shih from Illuminationsupply.
    If you want to see what underwater fluorescence looks like (which is what I used these LEDs for),
    and why some people say that it is like being in the movie "Avatar",
    have a look at this video of mine:
    http://www.youtube.com/watch?v=4V9TCdCbX6U
    BTW, it turned out that fluorescence is much stronger with blue light than with UV,
    apparently because marine life has adapted during evolution to the properties of water,
    which is more transparent to blue light than it is to UV.
    Enjoy!
    Some of us here, like Blasterman and myself, are into reef aquariums, so we are familiar with the fluorescence of marine life. 420-500nm produces the bulk of the fluorescence, and different wavelength ranges brings out different fluorescent proteins. 455nm royal blue has the widest effect, but play with some other violet, blue, and cyan LEDs to see how different things get. 365nm UV does some interesting things for fluorescence also, so try that too.
