ArmyTek
Results 1 to 3 of 3
Thread: Mily LX2 Elendil Special Reserve programming options?
    Default Mily LX2 Elendil Special Reserve programming options?
    I picked up one of these beauties on the CPFMP. This is my first milky modded light and I have no experience with how the programming works and what all my options are. I was curious if anyone can share of if there is a site that has all the info?
    Elzetta M60 | Fenix E01 E05 | Surefire 6P C2 E2E E2L-AA | Malkoff: M61-219 M61HCRI M61 Malkoff 3D Maglite
    Certified Malkoff Junkie....
    Flashaholic* John_Galt's Avatar
    Feb 2009
    SW, PA
    Default Re: Mily LX2 Elendil Special Reserve programming options?
    Milkyspit lights are not usually programmble, as in you set up how the light works [ie: HDS/cracked Novatac/Novatac 120P/Armytek].
    His UI's are based on a series of sub-menu's and drives.
    Think: 4x4 truck. Different gears in the manual transmission [each is a sub-menu] with a hi/low range transfer case [mizer/staminator drives].
    Midway down this page in Milky's thread you can see how the standard "Califon" firmware UI is set up. The person requesting the mod service can also ask him to program the driver differently [for about $30], adding additional levels of output, additional sub-menu's, etc.
    http://www.candlepowerforums.com/vb/...-Part-4/page18
    I believe that this Elendil mod has the same basic UI as in the above link. Hope it helps.
    I love my HDS/Ra Clicky... My only wish would be a 5th(accessible thru a 2click press) mode, and a 2AA tube.
    Flashaholic mikes1's Avatar
    Oct 2006
    Hertfordshire England
    Hope this helps
    You don't win friends with salad!
