Maxpedition
Results 1 to 8 of 8
Thread: Brightest LED Headlamp w/ good battery time?
    Default Brightest LED Headlamp w/ good battery time?
    I just joined Search & Rescue and I need to buy a headlamp. I don't know much about headlamps and I thought i'd ask you pro's.
    What's a good LED head lamp that is bright and gets at least 4+ hours of battery time and does not cost more then $100.00?
    Thanks in advance for helping a newbie!!! Your valuable input could help save lives, thanks!
    Flashaholic iron potato's Avatar
    Aug 2011
    Inch'on-jikhalsi, Korea
    Default Re: Brightest LED Headlamp w/ good battery time?
    Not an expert, but I have got headlamp from,
    Zebralight H600 US$89
    Spark ST6-460NW ard US$99
    But for your requirement of 4+ hrs, u may need spare batteries I believe.
    For H600 :-Light Output
    • High: H1 420Lm with 750Lm turbo in the first 3 min (2.3 hrs) or H2 170Lm (7 hrs) / 270Lm (4 hrs) / 420Lm (2.4 hrs) / 4Hz Strobe
    • Medium: M1 65Lm (18 hrs) or M2 21Lm (50 hrs)
    • Low: L1 2.8Lm (280 hrs) or L2 0.1Lm (80 days)
    • Runtimes are tested using Panasonic NCR18650 (2900mAH) batteries. Light output are out the front (OTF) values. All levels are current regulated.
      H600 have spot & H600F froasted lens model to choose from.
      For Spark ST6-500CW :-
      Super: 500lm/1.4hours
      Max: 320lm/2.5hours
      Med1: 150lm/8hours
      Med2: 50lm/28hours
      Low: 8lm/8days
      ST6 came with changeable clear & diffused lens.
      ST6 able to accept reverse battery polarity, meaning it doesn't matter u slide in the battery top or end first, it will just work, especially changing battery in a rush & dark area.
      Hope this help, or wait for some expert to chime in
    My list of flashlights, chargers & batteries
    Mar 2012
    The ZebraLight and Spark are nice headlamps, but they use 18650 Li-ion batteries. These require special chargers and special handling.
    If you just want to use regular AA batteries, I would look at the Princeton Tec Apex.
    Dec 2007
    USA
    Does it have to be a headlight?
    The Fenix headband + your choice of light is still a good system.
    Enlightened vaska's Avatar
    Feb 2010
    Moscow, Russia
    Well known in Europe Scandinavian brand Silva: http://silva.se/all-gear
    Enlightened florinache's Avatar
    Mar 2012
    Iasi, Romania
    Fenix hp11
    Flashaholic* Lighthouse one's Avatar
    Ephrata, Pa
    I recently got the spark st6-500cw. I ran a test at work
    With the light on high (220 lumen) I got 4 hrs and 5 minutes on a 2600ma ultrafire battery. This was on a battery fresh out of the charger. 18650 batteries.
    It is easy to carry extra batteries along. 1 extra battery will get you all night...or a couple of batteries will let you run turbo for a long time too. The light runs on turbo with out overheating continuously...a great feature.
    Be aware the light seems more like 400 lumens....but this is partly because the light has a strong spill and a decent bright center area. You will still want a powerful flashlight along with a headlamp. We are talking bright light to 100 feet...and longer distance if it's real dark.
    This is a very good quality light. Just be aware the some of the longer high capacity batteries can be too tight a fit. The end cap has a strong spring in each end- and the longer batteries can put a bit of a strain on the battery end.
    Light 1
    Striker VG, SL Scorpion Led, Huntlight FT01, Wolf Eyes 9 v Raider, D-Mini Lumapower, Drumlights, Surefire G2, Dereelight ,Ultrafire 500, Power on Board HID, Olight T 20 Q 5, Zebralight H-30, Nitecore EX 10, Eagletac T10C2, MTE P 7D, Icon Rogue 2
    Flashaholic Bicycleflyer's Avatar
    Mar 2008
    Cincinnati, OH
    Personally, I would look at something from either Black Diamond, Princeton Tec, or Silva. These are the lights used by experienced mountaineering people. The Apex is a good choice, I have the extreme model with the external battery pack. It is my preferred outdoors light, but it's a bit too much for everyday around the house use. For that I just ordered a BD Spot.
    I should ask...Do you want... No battery pack, battery pack on back of head, external battery pack?
    Do you need a flashing mode?
    Do you think you would want Red LEDs?
    Do you want to use AA, AAA, Lithiums, NiMh (rechargeable)
    Answering these questions should help us narrow the field.
