NITECORE -- Keep Innovating
Page 1 of 3 123 LastLast
Results 1 to 30 of 69
Thread: TAIN TITANIUM HYPERLUX - based on a design byTNC
    *Flashaholic* easilyled's Avatar
    Jun 2004
    Middlesex, UK
    Default TAIN TITANIUM HYPERLUX - based on a design byTNC
    Chris of TnC_Products very graciously consented to a limited run of Titanium lights being produced by CPF'er Tain.
    This run was a tribute to Chris's famous Hyperlux line of lights which in my opinion are amongst the most beautiful lights ever designed.
    I was culpable of egging Tain into this by pleading with him to make one of these for me when I first saw a picture of his personal 2-piece Hyperlux tribute light in the "Show your lights with Trits Thread"
    Luckily for me and a few others, Tain consented to this. The result is a small run of 2-piece and 3-piece Hyperluxes that are very faithful to Chris's design. The 2-piece version has slightly more fins and both versions have Titanium push-button switches with six tritium vials arranged hexagonally. The knurling for the 2-piece lights is raised. A decision was taken for the 3-piece Hyperluxes to have flush knurling (which is very difficult to execute)
    For my personal 3-piece lights I requested the smooth areas to be slightly trimmed where they bordered the knurling for a "cleaner" look (rather than the more merged appearance of true flush-knurling) hence technically the knurling in my 3-piece lights counts as "slightly" raised.
    Tain handled everything like a pro with excellent communication and frequent updates with tantalising pictures. His photographic skills are formidable and do justice to the excellence of the machining which turned out flawless with tight tolerances and exquisite knurling.
    I will let my (amateurish) pictures attempt to do the talking ....
    http://i21.photobucket.com/albums/b2...x/DSC_0172.jpg
    http://i21.photobucket.com/albums/b2...x/DSC_0174.jpg
    http://i21.photobucket.com/albums/b2...0174_knurl.jpg
    http://i21.photobucket.com/albums/b2...nurl_close.jpg
    http://i21.photobucket.com/albums/b2...x/DSC_0149.jpg
    http://i21.photobucket.com/albums/b2...x/DSC_0151.jpg
    Last edited by easilyled; 08-08-2017 at 11:16 AM. Reason: Photobucket links migration
    We are all flotsam and jetsam being carried by a relentless tide towards our ultimate fate!
    Flashaholic* RPM's Avatar
    Jan 2005
    So. Cal
    Default Re: TAIN TITANIUM HYPERLUX - based on a design byTNC
    Those have got to be hands down the most handsome Ti lights I have ever seen....
    I'm surrounded by precision machined parts all day and that my friends is absolutely beautiful lathe work.
    The knurling appears flawless!
    I am not worthy!!!
    R-
    Absolutely magnificent my friend!
    Flashaholic* dlmorgan999's Avatar
    Feb 2012
    Tigard, OR
    As someone who currently owns two TnC lights and is about to own two more, I must say that those lights are really beautiful! I sure wish Tain would do another batch. I'd be in for one (or more) for sure!! The switch really adds a nice touch.
    Here is a list of my lights.
    Gorgeous gorgeous gorgeous!!!!! The one on the left in the first pic. That is probably the best looking titanium flashlight next to the 007.
    What type of light engines are in them?
    Jun 2004
    Middlesex, UK
    Quote Originally Posted by dlmorgan999 View Post
    Out of respect to Chris, no more batches of these will be produced by Tain. Chris may well revisit these lights himself at a later stage and we have to be thankful for his generosity in allowing this limited run.
    Jun 2004
    Middlesex, UK
    Quote Originally Posted by badtziscool View Post
    The L.Es are very beefy screw-in brass canisters (for maximum heat-sinking).
    Drivers:-
    4-level constant current, 2500mA max OR 3-mode Low-Med-High, 2800mA max OR 5-mode Low-Med-High-Strobe-SOS, 2800mA (all with memory).
    Emitters:-
    Cree XML, T6-0A(8000K), T6-3C(5000K) or T5 - 5A3(4500K)
    Flashaholic* mohanjude's Avatar
    Dec 2011
    Cardiff, UK
    Very nice lights - these look like the 'Rolls-Royce' of lights - the type of lights you can you only dream off.
    During the day when I don't need a torch ... RC is my hobby http://rc.runryder.com/helicopter/gallery/47842/Always on the lookout for McGizmo/Kuku Titanium torches with Trits..
    Flashaholic* Henk_Lu's Avatar
    Oct 2007
    Golden Cage
    I'm a lucky owner of 2 the Hyperluxes, a 2pcs and a 3pcs. Indeed, they are perfectly machined and combined with the nice design they surely are the current crowns of my collection...
    While the 2pcs was the first one made, I begin with the 3pcs, where I chose the combat grip, but also ordered a normal grip to be able to change, unfortunately I couldn't afford a second light (to be honest, I couldn't afford any of them...). A crenelated bezel is a must for a combat grip.
    The tail is the best part of this light, the builder changed the original design to accomodate the electronic 6-trit switch and the result is a real highlight!
    The knurling on both light is different and there are indeed 3 sorts of knurling : Raised, slightly raised and flat. My 3pcs has been given the slightly raised knurling, the best compromise in my eyes, I don't really like the look of flat knurling after all...
    The light engine is a 3-mode with 2,8A powering an XM-L, a neutral white T6-3C in my lights. There are 2 sorts of reflectors, for flood and for throw (easily changeable), I installed the flood one here, best to take pictures for sure! Around the emitter there's some glowing powder and I just realize I should have switched the light on for a moment before taking the picture.
    Here's my 2pcs light, featuring raised knurling, a standard tail and a smooth bezel.
    Here you see the raised knurling, machined as perfectly as the slightly raised knurling on the 3pcs light, but with a different look on the edges.
    While the working ends of these lights are very bright with their XM-L engines, the tails just glow constantly, thanks to a 6 trit-design. The colors could be chosen and that's quite difficult, I chose a more or less quiet (but colored) design for the 2pcs and a more vibrant design for the 3pcs. Maybe those switches look even best with only 2 colors (a brighter one for the lower layer and a dimmer one for the upper layer) or even a single color, there are endless possible combinations...
    Many thanks to TNC for giving the permission, to all people who were part of the project and making it possible, to Tain for the excellent management (also of all our special wishes and changements...) and of course to the builder, whose excellent skills brought these jbright ewels out of some massive titanium rods!
    My way : From Maglite and drop-ins over Fenix & Co to the real things - Customs and Titaniums!
    light your lite . ...
    Flashaholic* chipwillis's Avatar
    Nov 2007
    Minnesota
    I love the new one, I wish I could bought one at the time. enjoy.
    Flashaholic* ZeissOEM2's Avatar
    Jan 2005
    Norway
    The 3 piece is great
    Moderator
    arewethereyetdad's Avatar
    Nov 2003
    Kansas City, MO
    I felt honored to be included in this very special custom build. My Tain Hyperlux arrived today, about a week after the others received theirs, as I was holding out for a back-ordered blue trit tube for the six-tube tailswitch. Glad I did, as I got a special surprise: a one-of-a-kind proto switch whose hex-shaped core is bored and polished, with a 2x6mm trit installed in the center. The angled surface of the bored/polished core reflects the light of the center (and seventh) tritium, which provides the circular glow pattern. Really an ingenious design. This is such a great light - so flawless, so perfect. The knurling is second-to-none - it's truly amazing. I, too, opted for the slightly raised knurling - seems a more finished look. Very, very happy with this beauty.
    Pardon the dust (and the center is perfectly symmetrical - just a bad camera angle):
    Jun 2004
    Middlesex, UK
    Great pictures Troy and congratulations on scoring the proto 7-trit tail-switch.
    Moderator
    Nov 2003
    Kansas City, MO
    Quote Originally Posted by easilyled View Post
    Thanks Daniel! And Yitsan corrected my proto description, so I've revised it slightly (above). What an amazing light!
    Flashaholic* Obijuan Kenobe's Avatar
    Sep 2010
    Rotterdam, Netherlands
    The seventh trit sounds similar in principle to JHanko's 3D in miniature.
    The lights themselves are too big for my taste, but the build quality and in particular the knurling looks perfect.
    obi
    Stay sharp and bright for life.
    Have your knife and light handy at all times.
    Sent from a long time ago, in a galaxy far, far away.
    Jan 2005
    So. Cal
    Troy... If that light ever wants to visit So Cal, it's more than welcome to come and stay as long as it wants!
    uh, you can come too if you want. Sushi included.
    R-
    Flashaholic Midnight Run's Avatar
    Dec 2011
    Paris, France.
    It has all been said by all the lucky owners of these beauties but... Wow!!!
    These puppies are purrrfection in titanium!
    I feel privileged to own two 2 pc. and one 3 pc. combat grip Hyperluxes from heaven.
    Thanks to Tain for the AWESOME lead and weekly updates.
    And thanks to Chris Ogaz for being a genius flashlight designer .
    覧覧覧覧覧覧
    Tashi Bharucha Design
    Flashaholic* mr.snakeman's Avatar
    May 2008
    Stockholm, Sweden
    Iエm also a member of this exclusive club wth a two piece and a three piece now in my possession. I can only agree with what everyone else has said: magnificant workmanship and execution. These two lights are truly the cream of my Ti lights collection!
    Jan 2005
    Norway
    edit - offer withdrawn .
    Feb 2012
    Tigard, OR
    I'm interested! PM sent.
    Flashaholic* ma_sha1's Avatar
    Jan 2009
    CT, USA
    Beautiful! Looks identical to Arcmaia lights?
    My Mods.. http://www.candlepowerforums.com/vb/...5&postcount=78
    Hobby only, I don't do custom mods as a service, thanks for understanding.
    Jul 2009
    Maryland, Near DC, USA
    Those look fantastic. Can I have one?
    Flashaholic* tobrien's Avatar
    Dec 2005
    Georgia Highway 441
    Quote Originally Posted by fyrstormer View Post
    same here?
    Flashaholic* davyro's Avatar
    Sep 2011
    Durham,England
    Being from the UK easilyled you'll know exactly what i mean when i say "These are the Dogs *******",some of the best looking & finest machining I've seen in a light.
    What another new light!!!
    Jun 2004
    Middlesex, UK
    Thanks davyro - I know what you mean and I agree.
    Flashaholic* emu124's Avatar
    Aug 2010
    Switzerland / CONUS address
    Here's my Tain Hyperlux 3 pcs. with flush knurling. I only can agree with what was posted before.
    It's a real masterpiece
    But pics say more than words :
    Thanks to everybody who was involved in this project and a special thanks to Tain for the great communication
    Flashaholic* ArsMachina's Avatar
    Apr 2005
    Germoney
    I have no words to add, but two pictures of my light :-)
    Jochen
    Flashaholic* F250XLT's Avatar
    Dec 2008
    I can see the Windmills...
    You guys are killin' me, SO beautiful...
    "I am not a Collector" - Tim
    Real nice, piece of art
