No they do not, but there are other lights available with the same level output that have smooth reflectors. They will not have the same type of rear switch. The Xtar TZ58 has a smooth reflector and a different interface. It puts out the same amount of light on high as the XT-11 but does not go as low. Also the Xtar TZ20 has a smooth reflector, puts out about the same amount of light and has a similar beam pattern. The TZ20 in XML-U2 can only use 18650 batteries unlike the Klarus that can use CR123A or 16340 batteries also.
I am sure there are others
