Orbita
Results 1 to 10 of 10
Thread: A question about batteries.
    Default A question about batteries.
    A workmate bought a HID torch in China. It worked well, until he tried to measure the power of the battery, using a voltmeter.
    There is a warning, on the battery, that one should not shortcircuit - But he did.
    Now the torch will note "fire"
    Battery seems to work, but no light comes from the bulb.
    I have found a similar battery,on the net, from China. The only differenve is, that hes battery say version 2.0.
    http://www.aliexpress.com/product-gs...olesalers.html
    Would this battery fit the 28/35 Watt HID torch ?
    Can the old battery be fixed with a new circuit ?
    Flashaholic* ma_sha1's Avatar
    Jan 2009
    CT, USA
    Default Re: A question about batteries.
    Quote Originally Posted by Alland44 View Post
    Most likely will work, these are generic style HID & battery, they appears to have been standadized.
    Yes, the question is can you o it? If you had to ask, the answer is probably no.
    The battery inside is cheap 2200mah, if you open it up, you might be able to upgrade to panasonic 3100mah & gain 30% run timer.
    My Mods.. http://www.candlepowerforums.com/vb/...5&postcount=78
    Hobby only, I don't do custom mods as a service, thanks for understanding.
    If the battery is good why are you looking for a new battery? Maybe the light has a fuse somewhere that needs replacing.
    Jul 2011
    The High Plains of Wyoming
    ...There is a warning, on the battery, that one should not shortcircuit - But he did...
    When you say he did short circuit do you mean just taking the voltage measurement with one probe on the positive and the other probe on the negative contact or did one probe accidentally touch both contacts at the same time?
    Just taking a voltage reading properly would not be a short circuit.
    Jul 2011
    Quote Originally Posted by ma_sha1 View Post
    I don't think so. The batteries on the site the OP linked to are 11.1V, 4400 mAH batteries and they have three contact posts on one end. Must be several cells stacked together.
    Quote Originally Posted by CoherentRays View Post
    I do not know what he did measure. What contacts he short cicuited, and he doesn´t know himself. Result is a working battery (seemingly) but the bulb do not fire.
    Leds works and the two colors in the rear works.
    Thank you for that answer.
    Do you have a link to that upgrade thing ?
    I have found a similar battery,on the net, from China. The only difference is, that hes battery say version 2.0.
    This can be read two ways. The battery of my workmate is the version 2.0.
    Will this battery work ?
    Wrong post. Wrong forum.
    My workmate just bought a 11,1 volt 6.600 Mah battery on ebay. This one has three positions, instead of two.
    Could this be a problem with his 28/35 watt light ?
    With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion. Steven Weinberg
