Olight - S1 - MINI
Results 1 to 8 of 8
Thread: Test/Review of LG 18650 C2 2800mAh (Orange)
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/Review of LG 18650 C2 2800mAh (Orange)
    I could not find any specifications on this cell.
    This battery can be charged up to 4.3 volt.
    The batteries has a high voltage, even at high loads. The capacity is below the specified capacity.
    These are unprotected cells.
    Most LiIon chargers can only charge to 4.2 volt, a possibility to get 4.3 volt is a hobby charger with adjustable charge voltage (Like iCharger).
    LG 18650 C2 2800mAh (Orange) at 4.2 volt
    Reducing the charger voltage to 4.2 volt reduces the capacity with about 200 mAh.
    Conclusion
    LG does make very good cells and the higher output voltage when loaded can be interesting for some applications. But it requires a special charger.
    Notes and links
    I have only added the 4.3 volt test to the bar charts, but both 4.2 and 4.3 volt can be found in the 18650 comparator, this makes it possible to compare voltage at different loads and charge conditions.
    The batteries was supplied by cpf user "Candle Lamp" for review.
    How is the test done and how to read the charts
    How is a protected LiIon battery constructed
    More about button top and flat top batteries
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Jun 2010
    South Korea
    Default Re: Test/Review of LG 18650 C2 2800mAh (Orange)
    Great work. Thanks a lot for your time & efforts as always. HKJ!
    It seems 2800 is not so good compared to 3000mAh.
    I appreciate your great work.
    KH
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    They are rated at 200mAh less capacity and they have about 250mAh less capacity, it is not that big a difference. They do have the higher voltage, compare to other LiIon batteries.
    But if I had to select what batteries to use with a 4.3 volt charger, I would select the 3000mAh batteries.
    Flashaholic* jasonck08's Avatar
    Sep 2007
    Redding, CA
    All the 4.3v batteries I know of are 2800's. 3000's are all 4.35v.
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by jasonck08 View Post
    I did not express my self clearly enough, I would prefer a 4.35 volt 3000mAh at 4.3 volt, it has slightly more capacity.
    Here is a curve from my comparator:
    [QUOTE=HKJ;3950992]LG 18650 C2 2800mAh (Orange)
    Hi HKJ,
    I have some of these cells and an OPUS BT-C100. Should I charge them at 3,7 or 3,8V?
    Thanks,
    Lucian
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Lukis View Post
    Thanks,
    Lucian
    They are 4.3V cells, this means somewhere in between.
    If you want maximum capacity from them use 3.8V (They will be slightly overcharged).
    If you want maximum lifetime from them use 3.7V
    Hello again,
    Thanks you for the answer. I went into details due to the fact that these type of 4.3/4.35V cells are rising questions from users like me (beginners). I have also some D1 and I stick to them at 3.8V charging. The idea is to use them with Opus BT-C100 as a power bank, if no issues.
    I appreciate your work,
    Lucian
