cdrake261
I acquired an older projector with a working lamp at the moment, however I want to start working on a bright led setup for this...several thoughts comes to mind:
1) my unit is large, so easy to swap to a led setup.
2) I have leftover water cooling from an old computer project.
3) fewer sst-90's or more xm-l.
4) what tint LEDs to give natural lighting.
I would like something bright enough to use in my room without the need to black out my windows or use black curtains, running cooler than the lamp it uses is a plus. Also like to find a way to power on the LEDs when I turn the projector on...I also need to figure out how to adjust the brightness as well.
Here's my projector with an Xbox case to show you the size of the projector...
Any ideas?
Any ideas?
