Bronte Flashlight
Page 1 of 10 12345678 ... LastLast
Results 1 to 30 of 299
Thread: TorchLAB V4 Triple LED drop ins - Full Boost, Thermal, and Voltage Regulation
    Flashaholic* Moddoo's Avatar
    Nov 2008
    Minnesota
    Default TorchLAB V4 Triple LED drop ins - Full Boost, Thermal, and Voltage Regulation
    Fully Boosted Thermal and Voltage Regulated V4 Triples cranking out up to 1400 lumens
    Custom built engines for your favorite hosts
    Available with Cree XPE/XPG and Nichia 219 Hi CRI
    New V4 Triple: Smart voltage based cell counter, cell monitoring, voltage monitoring (extending IMR cell life), and a 2 step thermal management and output reduction system. These features bring additional security and reliability to our existing L3 model, but they also allow us to push the envelope. Thermal Management means we can push more heat, more amps, and more lumens.
    All models come with electronic reverse polarity protection, critical overheating cut-off (full off at 120°C) and low voltage cutoff at 2.2V.
    Lithium Battery Monitor
    Battery monitoring function is a new feature of V4 Triple LED drop-ins. It implements a fully-automatic lithium battery protection function with cell count detection. It's set to 3.6-3.7 nominal voltage and admits single (1S, 3.7V) or two-in-series (2S, 7.4V) battery configurations.
    Battery Stretch Function
    This feature is a new feature of V4 Triple LED drop-ins, and nearly doubles the runtime when the full mode is initially used. The output is reduced to 10% at 10% of the cell. So it lets the remaining 10% of battery to last 10 times longer. It's still possible to return to full mode when required by the situation
    Thermal Management
    In addition to the hardware overheating cutoff (at 120°C) the V4 Triple LED drop-ins implement a 65C (149F) temperature setting at which the output is reduced to prevent lithium battery overheating (when it shares the same housing with the light engines). High-temperature warning is introduced in the stand-by mode (fast red-indicator blinking during which it's not recommended to touch the flashlight head).
    • Fully regulated output between 4.8 and 9.5 volts
    • Below 4.8v it drops out of regulation and continues running until about 3v
    • The output is reduced to 10% when 10% of the cell(s) capacity remains
    • Up to 96% efficient driver with 2 lithium ion cells
    • Integrated thermal overheating protection at 120C (248F)
    • Thermal Management reduces output to 10% at 65C (149F)
    • Shock and vibration tolerant materials and components
    • Heavy duty positive contact spring
    • Solid brass negative contact ring
    • Tight fit for best thermal contact with your host
    • Shock proof materials, components, and design
    • Suitable for use in weapon mounted lights
    • Hard anodized black finish for superior thermal emissivity and durability
    • 24 gauge mil-spec wire with 19 strand, silver-plated copper conductors, teflon insulated
    • Multiple independent LEDs for more output than single LED designs with similar wattage
    Warnings:
    • This light creates excessive heat
    • This light may cause eye damage
    • This light may burn the skin at close range.
    • This light may cause combustibles to ignite
    • This light is not a toy, keep away from children
    POWER SUPPLY OPTIONS:
    Example of setups using L1 or L3 (high mode) Triple Drop-ins
    • Surefire 6P, C2, Z2:
    you can run 2xIMR 16340 on L1 or L3 Triples for 20 minutes of runtime
    2x16340 not recommended for H1 or H3 Triples
    • Bored Surefire C3, 9P, or 6P with extension.
    you can run 2 x protected 18500 for about 75 minutes of runtime
    IT IS SAFE TO RUN THESE ON 2 X 17500 CELLS
    This drop-in runs on 1, but is fully regulated with 2 rechargeable cells
    It will give full output with 2 cells until they reach 3.0V each and output is reduced to 10%
    With a single lithium cell, It will run at approximately 75% output (800+ lumens) in this configuration.
    These are not regulated on 1 cell
    A single AW 18650 3100mAh cell will provide about 90 minutes of runtime.
    You can run a single 17670 for about 35 minutes.
    DO NOT USE 1 or 2 PROTECTED 16340 WITH THESE
    Protected 16340 are not recommended at this current draw.
    Do not run primary CR123 in these. The boost driver will drain them harder and harder until the cells overheat, and may explode.
    Default Re: TorchLAB V4 Triple LED drop ins - Full Boost, Thermal, and Voltage Regulation
    These are fantastic! You're not running a buy back on pre-loved V3 triple engines towards the purchase of a new V4 are you??
    Unenlightened
    Apr 2012
    Oh you sneaky guy! I saw that these were added to the site and out of stock earlier and was heart broken . I was so lucky that I left my browser open on my iphone to see that these just came instock tonight. I think I sprained my back from pulling out my wallet so fast. Can't wait to get it in the mail.
    Any news on when the 1400lumen XPG version of these will be in stock? Also do you plan on doing a run of GID DB Moddoo bodies and cryos cooling bezels to match those GID triad tailcaps? Id love to get my hands on something like that to make a flashlight for my gf that she might be able to find in her purse .
    Sep 2009
    Indonesia
    Quote Originally Posted by Fluxo View Post
    I don't think GITD will glow unless it's recharged especially if it's kept in the purse. I thought about the same and ended up giving one flashlight with tritium instead of GITD stuff.
    Flashaholic* beach honda's Avatar
    Apr 2007
    Concrete Jungle Surrounds Me
    When will these be available?
    -Chr1s-
    Got Lights? USE EM!!
    Sep 2009
    Indonesia
    Apr 2007
    Good lookin out fabienne
    -Chr1s-
    Low-Med-High. come on down!
    Quote Originally Posted by Cerealand View Post
    +100000000000000
    Nov 2008
    Minnesota
    Quote Originally Posted by warmurf View Post
    We do our best to satisfy you guys, but maybe that's going a bit too far!
    Thanks for the order.
    We will have the XPG 1400 lumen models in stock later this month.
    Quote Originally Posted by badtziscool View Post
    +100000000000000
    Already built and should be in Dan's hands soon.
    Unenlightened
    Mar 2006
    Texas
    Just bought 1....must be my lucky day!
    Thanks for the heads up fabienne!!
    Quote Originally Posted by Moddoo View Post
    Awesome!
    Another question. I'm assuming the 1400lm version is only available with XPG cool? No xpg neutral or xpe?
    Nov 2008
    Minnesota
    Awesome!
    We are only able to achieve the 1400 lumen level with the Cree XPG R5 driven at 1.5A each (4.5A total) at this time.
    We continue to source the best available leds for you all.
    These H3N Nichia 219 HI CRI are driven at a solid 1.5A each (4.5A total) for about 1100 lumens of 4500K Hi-CRI goodness
    DO you know when you will have moddolar slim cell tubes back in stock?
    Nov 2008
    Minnesota
    Quote Originally Posted by kingcow View Post
    All sizes are currently in stock right now.
    Sorry, I mean in gray HA.
    Apr 2007
    Can anyone chime in with info between the H and L models? I have a bored C2 that I want to run one of the high CRI units in. Will an 18650 be straight to get at least 75% power for...say...an hour?
    Any beam shots with the hi CRI? Is this more flood/wall of light or throws?
    thanks
    cB
    -Chr1s-
    These drop-ins should be more of a wall of light. I have the Torchlab L3C.
    The versions that I see on their site right now are H-M-L or L-M-H. It all depends on what you use the most. I use Low and Medium most of the time; I rarely use high. For that reason the L-M-H model is best for me.
    I too am interested in the beamshot. I expect a big giant neutral circle of light.
    Sorry for the confusion. From the web site:
    Power: L (low) or H (high) or D (direct drive)
    'L's are the standard model, familiar for so many years.
    L1 and L3 models are at the standard drive level, equating to 1100 cool lumens
    H3 models are at the new (increased) drive level, equating to 1400 cool lumens
    219 setups are less than cool and single battery setups are less than dual quoted above.
    219 and XPG can handle the H power level. XPE cannot and are only available at the L level.
    If there is interest, we can do 219's in a L3 configuration
    H1's are possible, but require full electronics, so would be the same price as H3
    IMR 16340's also cannot handle the H power level. IMR 18350 are the smallest usable size.
    We have not had these long enough to do runtime testing.
    Here are a full complement of beamshots. The H3 Nichia is in the bottom left corner.
    Have the Triple H3 L/M/H Neutral gone on sale yet or have they already sold out?
    Have a tritium vial to install? See my sales thread for Norland 61 optical adhesive.
    Quote Originally Posted by RocketTomato View Post
    The first LMH 219's are scheduled to land, tomorrow afternoon (PST)
    Quote Originally Posted by ElectronGuru View Post
    Excellent, looking forward to it.
    By the way, do you have an ETA on when Nat HA Moodolar parts will be back in stock?
    Is it just me or does the xpe r3 (outdoor) have a REALLY nice tint and color rendition. Dare I say, nicer than the Nichia 219???
    Either way, I'll be at my comp ready to pick up a nichia lmh when it becomes available.
    Enlightened arcane's Avatar
    Aug 2009
    OC / SoCal
    Is that ~90 mins on HIGH w/ single 18650 3100mAh cell?
    Nov 2008
    Minnesota
    More Nichia high CRI triples in both LMH and HML in stock now guys.
    We will have more runtime data and other results from the lab soon for you all.
    Thanks for your support.
    Flashaholic red_hackle's Avatar
    Aug 2010
    London
    Are you also going to release the new triples as updated Moddoolar heads?
    Touch my food, feel my fork!
    Nov 2008
    Minnesota
    The H3N Triple Nichia 219 runs for about 70 minutes on an AW 3100 cell before the voltage of the cell triggers the Battery Stretch Function where the light changes to 10% output.
    We will have more data on the remaining runtime on 10% and Medium, and Low soon.
    I will get the data into some nice graphs for you to see.
    We will have these available in Moddoolar Heads soon for you guys.
    Just need to have some laser work completed.
    Flashaholic Filip's Avatar
    Oct 2004
    Czech Republic
    Tom, Dan,
    Concerning throw what is correct:
    1. XPE > XPG > 219 or
    2. XPE > 219 > XPG?
    Jul 2011
    Brisbane, Australia
    Has anyone had a chance to try these? I received a V4 XP-E neutral yesterday, and have tried running it for 15 minutes in a bored 9p with 2 x AW 17500's to see if the thermal regulation would kick in. It didn't, but the light never got too hot to touch. The whole body of the light was very warm though. I did notice that the light wouldn't go into low mode when it was hot.
    I know it's like asking how long is a piece of string, but how long would you normally run these before the thermal regulation kicks in? I'm in a room with an ambient tempreature of 20C.
    Dec 2009
    Bay Area, CA
    Tried mine yesterday (219 version). Got pretty hot and did not notice thermal regulation either.
    Just another 'fiend looking for his next hit.
