ThruNite
Results 1 to 21 of 21
Thread: 3 is a Charm, 4 is a Bust! What did I do wrong with the Stanley HID?
    Flashaholic* Northern Lights's Avatar
    Jan 2006
    Southwest
    Default 3 is a Charm, 4 is a Bust! What did I do wrong with the Stanley HID?
    In two days time I went to three Pep Boys in Tucson and got 3 defective Stanley HIDs and a few days later picked up from Pep Boys in Sandy, UT the fourth. All did not work. Three of them when plugged into AC for the required 8 hour charge showed a steady green full charge light; one of the lights did flash red/green indicating it required the initial charge but it flashed for only a few minutes.
    All four would not illuminate when turned on. I tested one on the direct DC cord and it came on.
    What goes here? Did I screw up or is this part of the Stanley malfunction?
    Each Pep Boys it appears keeps one in inventory, I did a lot of miles to get the HID. Wal Mart informed me they no longer inventory the HID. Where can I find one? I see them on Amazon but my luck suggests I would be facing a nuisance return item situation if I purchased another broken one.
    Shortly I will be traveling MT, ID, UT, AZ down the I-15 corridor if anyone can answer: Where do I get one?
    Or is there something out there that is similar to the N30 or HIDC10? BTW- my N30 bit the dust, the battery problem led to a burn out of the ballast once I put it on 12V sla, the battery held the voltage and did not dip unlike the 12V and 14.4V on NiMh packs I fooled with.
    Thank you CPF,
    NL
    edit: see post # 14 it is 5 in a row now!
    <; )}}}}>< I fish therfore I am... pic links: '03,'07,'08
    Flashaholic* ma_sha1's Avatar
    Jan 2009
    CT, USA
    Default Re: 3 is a Charm, 4 is a Bust! What did I do wrong with the Stanley HID?
    Possibly they all came from the same central warehouse, possibly same lot & really old, the battery are all dead due to long storage w/o charging?
    Is this the older version? The new one has less watts but it's smaller & scored pretty good OTF at PF18 meet.
    My Mods.. http://www.candlepowerforums.com/vb/...5&postcount=78
    Hobby only, I don't do custom mods as a service, thanks for understanding.
    BVH's Avatar
    Sep 2004
    CentCalCoast
    First part deleted. Guess I was thinking about your post some time ago on the N30 battery and took off in the wrong direction!
    From what you describe, it's the SLA's. These have probably been on the shelf for at least a year, probably more. A dead SLA on a brand new Stanley is fairly common. Do they even manufacturer them any longer?
    G.E. 1942A WWII 60" Anti Aircraft Carbon Arc (Sold), 1KW Marconi Radar Sys Short Arcs, 1KW VSS-3a Tank Light, 600 Watt M-134 Gatling Gun Short Arc, 175 Watt Megaray, 300 Watt "Locator's", 150 Watt Short Arc Communicator, Maxabeam 12MCP, LarryK14@52V
    Flashaholic* FRITZHID's Avatar
    Jun 2011
    Cocoa, FL
    i don't believe they do. it IS the SLA, it's not a hard or expensive replacement. can do it in about 10 mins if versed in any electrical work.
    if your not wearing a #12 welding screen than it ain't bright enough! "Hand-Sun H.I.D." 55w & 75w(for sale), Rocky 3w LED, Stanley 109 35w mod'd, Maxa-Beam Gen II, 55w hid/100w incan Vector Twin, 400w MH long arc, 100w MH mid arc.
    Jan 2006
    Southwest
    Quote Originally Posted by FRITZHID View Post
    Quote Originally Posted by ma_sha1 View Post
    "More power, Scotty, more lumens plzzz!"
    "She gonna blow cap'n..." My story; I like LUMENS!
    So does this mean that it would be OK, even a wise idea to again search out the old HID and just change the SLA??
    BVH's Avatar
    Sep 2004
    CentCalCoast
    Yes, go for it! Also see here for a turbo boost option.
    http://www.candlepowerforums.com/vb/...=stanley+boost
    I wonder if 3 of the safe chemistry 26650, 3.6 amp cells from battery space would fit in the space?
    Flashaholic* larryk's Avatar
    Jan 2003
    Milwaukee, Wi. USA
    [/QUOTE]I wonder if 3 of the safe chemistry 26650, 3.6 amp cells from battery space would fit in the space?[/QUOTE]
    I just checked mine and 3 or 4 26650 or 26700 cells will fit with no modification to the case.
    Collins Dynamics CD-12, CD-12 Magnum, Microfire Warrior, Iluminator HID, Costco HID, ,Maxabeam, Polarian Helios, RayzorLite ,BarnBurner,and a bunch of small lights.
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    Gosh, what terrible luck. I wouldn't be surprised if the distributor is pulling these out of storage from the top secret warehouse featured in the last scene from Raiders of the Lost Arc. Seems like all the SLA's are going belly up.
    Hey, how about the Ryobi light with li-ion packs instead. It's a bit more but it should be lightweight and reliable.
    http://www.candlepowerforums.com/vb/...bi-35W-18V-HID
    Jan 2006
    Southwest
    Quote Originally Posted by Patriot View Post
    It is only 2800 lumens. REmember when our flashlights had only 65 lumen LEDs? I have an LED flashlight that is 3000 lumens, I build one that was 2700.
    The Ryobi is cute, serves a purpose and if you got the tools a nice addition to use the Li battery. But at 2800 lumens it is very dim.
    I prefer something brighter and BTW, as an HID it seems to be a waste of an idea and material when it can be out classed by simple flashlights and spot lights.
    BVH's Avatar
    Sep 2004
    CentCalCoast
    Thanks for the info Larryk!
    What about the FireFoxesIII, 40 watts in a tiny conventional flashlight stye package? Pricey compared to the Stanley though.
    Jan 2006
    Southwest
    Quote Originally Posted by BVH View Post
    OH BOY, thats a gottsta have and a half!!! I want one. But I gotta wait until end of June to check finances before I commit. Just retired... but I think I can swing one.
    How long is the group open until it closes?
    BVH's Avatar
    Sep 2004
    CentCalCoast
    Should be open till he has 20 claims on the list. Sent you a PM with link.
    Feb 2007
    Arizona
    Quote Originally Posted by Northern Lights View Post
    The Ryobi is too dim at 2800L but the Stanley is ideal at 3200L? Doesn't seem like much of a separation especially considering your trouble getting a working one.
    Jan 2006
    Southwest
    Just got back,
    BOTE trailer has axle/balance problem; factory installed wrong axle when it was built and it rolled over again this time destroyed and damaged into big bucks. So no little HID for now.
    Today I got another Stanley HID, I plugged it in and the indicator says full charge, I doubt it; seems to be the SLA again...
    where is a place to get an SLA for it, I will keep this one.
    edit: the SLA is shot in this light too , 5 in a row!!! this last one from Tucson again. It works on a small sla is hooked to the 12V input line!!
    Hope you can tell me where to get a replacement battery, I will open it later this week. Thanks CPF Family
    NL
    Jan 2006
    Southwest
    Me again!
    found a local replacement, exact except is 1.4 Ah and oem is 1.2 Ah
    Power Sonic, PS1212; $15
    I got a working Stanley HID
    Me again!
    Wow! What a hassle. You sure are persistent, though.
    You remind me of when I went searching for the Stanley when Walmart had them on clearance for $10. Found one at the first place I went to, that was it. Decided to stop searching before I spent more on gas than the savings were worth.
    Thanks for the heads-up on a replacement battery. Good to know, I've had my Stanley (old style hi-lo switch) for about 1 1/2 year without any problems.
    Sep 2008
    Melbourne, Australia
    I've got one of the Ryobi HID's and it is really great! Which model Stanley HID are you talking about in reference to the replacement battery, as I had always thought that the HID0109 had a 3Ah battery in it and with the model number being "UN3-12 3Ah" just as has been mentioned here!
    Sep 2008
    Actually here is a link to a PDF copy of the instruction manual for the Stanley HID0109 directly from the manufacturer's (Baccus Global) website and it clearly states that it has a 3Ah SLA. I had thought that 1.2Ah or 1.4Ah sounded too ridiculously small.
    Jan 2006
    Southwest
    Quote Originally Posted by cccpull View Post
    ...Thanks for the heads-up on a replacement battery. Good to know, I've had my Stanley (old style hi-lo switch) for about 1 1/2 year without any problems.
    How do you tell old from new style?
    Also like a politition...I lied. Looks like I will buy the FireFoxesIII, 40 watts very soon, I just gotta have one!
    Compared the Stanley to the DX 3k lumen (sku: 100215) last night. DX is definately flood, 3 light source, about 2x the width of the HID0109 at 200 yds., therefore a little dimmer in center of beam but not bad and off course it does not go much if any beyond the 200 yds. So if you want to light up the scene a ways away, grab the Stanley and if you just need your local camp, area, grab the DX (cute and easy to handle and carry spare batteries for! I have a head lamp that also recharges the 18650s so with several sets of 18650s I can rotate them through the head light and 3x Cree XRE 60T flashlight). I am amazed at the LED technology. But I like my HID too.
    *Lumens and beam width can be compared to a water hose and adjustable nozzle. The same amount of water but how much falls on a paticular spot when you open or close the nozzle? Same effect as spreading light around and easier to see in the "eye of the mind" if you picture the relationship that way.
    Did they work well at Pep Boys store?
    You didn't try it at store, did you?
    Thank you CPF,
    NL
    Love flashlight ,fishing, small game hunting, hiking, camping, climbing,
    http://www.cpfmarketplace.com/mp/showthread.php?274780-greeting-from-dankung-com-a-new-dealer
    Jan 2006
    Southwest
    Quote Originally Posted by Dankung View Post
    Since the instructions state it requires overnight charging before use I did not try it but plugged in the charger and got an immediate green LED which could only mean the SLA was fully charged or defective..
    The battery I replaced did the same but upon 12 hours on the charger, it tested dead with my meter and after using the BC-6 on it the charger and meter indicated dead and defective!
    I plugged the last 3 in at the store and although the indicator immediatel burned green I knew this indicated a defective battery but I took the lights home and charged them the appropriate time just incase the batteries would decide to play ball.
