Phoenix Electroforms
Results 1 to 5 of 5
Thread: Minigear UML-300E moded to Cree XML U2
    Default Minigear UML-300E moded to Cree XML U2
    Hi,
    I have ordered a Minigear UML-300E from Kaidomain.
    This is a "backup" dive light made with one Cree XPE-R2 led to use with one 14500 Li-ion.
    There is no driver (but i have seen only one little component during unmounting, perhaps a resistance ???).
    The waterproof is done by 2 O-ring between the head and the tube ; and 2 other O-ring between the head and the glass.
    At delivery, i change the original led Cree XPE-R2 to a one XML U2 (7000k color).
    To unmounting the head, you need to remove to 2 screws and desolder 2 wires from their pad. Then, the heatsink could be unscrew (it use the same thread than the tube).
    To change the led, i have bought one Cree XML U2 on www.dealextreme.com with aluminium star (16mm at delivery and milled to reduced the OD). You will have to solder 2 new "long" wires on the new led, pass it throught by the 2 "solder pad holes" and cut them after solder.
    I also replace the 4 original Oring :
    -FPM or viton, size 16x1 , qty 2 , for the tube/head
    -FPM or viton, size 17x1 , qty 1 , for the perimetre of the glass
    -FPM or viton, size 14x1.5 , qty 1 , for retaining of the glass
    Beam condition
    around 50cm distance
    around 1m distance
    around 2m distance
    Fisrt, I tested it in water in kitchen sink. The power is very good at the begining and decrease slowly with the tension of the 14500-900mAh Trustfire battery. I stopped the test after 1h05min without reach the integrated overdischarge protection of the battery. But after 1h05 there is not "a lot of lumen" : OK but always ON.
    At the beginning, the current deliverd to the led was about 1.5 - 1.6A --> 500-600 lumen
    I have tested it during several dives in seawater this weekend at a deep of 20m without any flood.
    Ptit Fred
    Please Do Not link directly to sales sites - Thanks Norm
    Flashaholic* 350xfire's Avatar
    Aug 2008
    Texas
    Default Re: Minigear UML-300E moded to Cree XML U2
    nice!
    http://tlslights.com/ your source for quality affordable dive lights, Mag-lite conversions and weapon lights. Now a Federal Firearms Dealer.
    Flashaholic* Packhorse's Avatar
    Nov 2007
    New Zealand
    How thick is the glass lens?
    Quote Originally Posted by Packhorse View Post
    I don't measure it during unmounting but it is very thick for a 17mm glass.
    I would say around 5mm : Safe enought to hold pressure.
    Ptit Fred
    Nov 2007
    New Zealand
    If I needed another torch I'd probably buy one of these. They look quite good for a small light.
