Page 1 of 2 12 LastLast
Results 1 to 30 of 52
Thread: DEFT-edc Enthusiast 86Kcd!!!
    Default DEFT-edc Enthusiast 86Kcd!!!
    The DEFT-edc Enthusiast
    The DEFT edc Enthusiast is the last in a distinguished line of hyper performance pocket spotlights. The Enthusiast is the ultimate expression of performance and takes what was already world class performance to the bleeding edge of current technology.
    This light is years ahead of anything else on the market. It boasts the highest specific power of any LED light of any kind in the world today be that portable or fixed. So as to not mislead we are not saying this is the longest throwing light in the world today because it is not. The ability of a light to throw is inextricably linked to the size of the light so there are some lights that can throw farther but they are all, with no exceptions, much larger. The beauty of the DEFT-edc Enthusiast is the phenomenal power in such a tiny package.
    How do we do it? Design-Execution-Quality components
    The LED is direct solder mounted to a custom machined "pill" made of solid high conductance annealed copper. This then is joined to the body with an interference fit to maximize the heat transfer. The copper used is very expensive 99.99% pure Copper with an IACS conductivity rating of over 101%.
    The optics used in the Enthusiast are extremely high precision and very very expensive. This part is one of the chief components that were upgraded for this model only. They are the single most expensive component used in the construction of this light. They are AR coated for high throughput and feature a short focal length for maximum light collection and larger beam width than the DEFT edc LR+. The main focusing optic is protected by an ultra-clear AR coated window. The effect of the two creates a rather jewel-like look which I have attempted to capture in the pictures.
    The LEDs used in this light are the top 12 performing out of 300 of the highest rated bin of the highest flux density LED available on the market and then modified to almost double the performance beyond that! In short these are the best performing LEDs that money can buy.
    This light was intended to be just that extra bit special as a way to see off this line of pocket throwers. As such they have also received a polish on key areas of the light which makes this light look and feel exquisite. The polish is good but not museum quality. Just want to be sure your expectations are in line with what we have actually produced. The contrast of the polished parts and the anodized portions are very beautiful and I am sure you will be delighted with the result.
    I wanted to keep the glow rings but wanted something a bit more upscale than the usual glow color of green. A silver powder was cast as an outer layer to give a metallic/pearlescent look in the day but retains a glow core that shines through at night. The tailcap button cover also features this same look.
    On this last model we have also incorporated a forward clicky tailcap which is the most favored setup and often requested in the past. It has a nice positive and light feel to it.
    Now to the performance figures. First a little bit of context. The original DEFT edc did 40Kcd typical which to this day is still industry leading.(specific output) As in...nobody has beaten it! Even some modders intentionally trying to beat it have failed much less some other manufacturer.
    After that we came out with the revolutionary LR at 60Kcd typical. That was followed by the amazing performance of the LR+ at 72Kcd. Now we have the DEFT-edc Enthusiast coming in at a startling 86Kcd typical!!! All this while retaining the same small body and good runtime. That is a staggering 115% increase over a light that noone has yet to beat(edc).
    As with the LR+ and it's predecessor the LR this light has a lovely neutral tint that also aids in color rendition and contrast outdoors. In this light however the colors seem even more saturated and beautiful. This is due to the high quality lens that has very low dispersion or color separation. The beam is still the same otherwise- that is to say that it is a projection of the LED die which is the most effective way of achieving maximum throw. I say this as a flashlight aficionado- this light feels and performs magnificent and I am very proud of it. There have only been 12 produced and 11 available for sale so this is an exceptionally small run.
    This is to be the last OMG Lumens product for a while and quite possibly the last in this size class ever for us. Although there are still plans for new flashlights under the OMG brand I will be taking a break from it to concentrate on a new flashlight venture that I will share with you all very soon.
    -From my wife Teresa, my sister Mandy and I we thank you all from the bottom of our hearts for your support all these years. It has been a labor of love.
    For purchasing and availability please see our online store.
    Specs:
    Head diameter-33.6mm
    Body diameter-25.08mm
    Length- 135mm
    Weight(without battery)- 114grams
    Battery- 1 Rechargeable Lithium-ion 18650(battery not included)(not compatible with 123 size cells)
    Pearlescent GITD tailcap cover
    Pearlescent GITD Grip Rings
    99.99% pure copper first tier thermal path(over 101% IACS conductivity rating)
    Reverse polarity protection
    Silver coated beryllium copper positive battery spring
    1.4A Regulated Driver
    Forward clicky switch
    Neutral tint Cree XP-C Q4
    High precision AR coated optics
    Typical throw performance of 86K cd/86K lux @1 meter
    Sydney, Australia
    Default Re: DEFT-edc Enthusiast 86Kcd!!!
    Wow. Just wow.
    That is absolutely beautiful!
    I thought the LR+ I have was amazing, but this is just a work of art!
    The one complaint I have about the LR+ is the lack of protection over the lens, I'm always paranoid I'll scratch it.
    A truly spectacular send-off for an amazing line of lights, You've really outdone yourself Michael!
    Cheers,
    Alex
    If I didn't already own the LR+ I would be buying one of these. This light looks awesome, nice way to send off the DEFT EDC series! Just curious, I was wondering if you had any of the standard green glow-in the dark rings left? I would like to add those to my LR+. By the way, anyone that hasn't used a DEFT before, you will not believe the throw these things have. Thanks, Joe
    beamshots?
    wow that light is stunning. if I didn't have an LR and had the $$$ to afford it I'd be all over this. Your deft edc lr is still my favorite light by far!
    these lights are selling fast.
    Flashaholic* Got Lumens?'s Avatar
    Mar 2011
    Champlain Valley
    Quote Originally Posted by netprince View Post
    beamshots?
    As soon as I get mine here, You will get some .
    Thanks Mike.
    I just purchased of one of the Eleven.
    It is the least I can do for you.
    Take Care
    GL
    Neutrālisflashaholic
    Flashaholic Draven451's Avatar
    Jan 2006
    USA
    Just when we thought the best could not get any BETTER!
    What an outstanding way to bring to close such a fantastic series of lights!
    I know you mentioned this light during our recent Dallas GTG and to finally see the pictures WOW!
    Once again your innovation and hard work has brought these lights to the next level.
    Thanks for sharing your passion and pushing the optics/leds/form factor into the STRATOSPHERE!
    "Light up the Darkness"
    Hi guys,
    I am afraid the flash light is already out of stock....what is only 11 items for the whole world? I guess nothing at all...
    Thank you Saabluster for your contribution to make world lighter!!!!!
    Saabluster can you tell us how much time did it take to run these items out of stock?
    Hi Saab,
    Awesome is a total understatement!!
    Wishing you continued success and lots'a'lux in your new venture.
    tgwnn
    Wait...
    I come back from my job to find out that all twelve Enthusiasts got sold out in less than SIX HOURS from introduction...
    Woe is me.
    I guess I'll have to be happy with the multi-voltage one.
    Damn this light is already out of stock,...will there be anymore made?
    Quote Originally Posted by ASheep View Post
    Wow. Just wow.
    Cheers,
    Alex
    The LR+ you have is amazing. And no need to fear the lens in the LR+ getting scratched. It is made of glass so it is very scratch resistant. The lenses in the Enthusiast are plastic however and although assembly would have been far easier and cheaper and the performance ever so slightly better I decided it was unacceptable to have the lens exposed.
    beamshots?
    Will try and get some up tomorrow night. Ran out of time tonight with all the emails back and forth.
    Quote Originally Posted by Draven451 View Post
    Yes I know. Everything can get better. Even this. If you remember the glimpse I gave you into the future has a light the same size as this one but with the power of the original DEFT. I'll have to bring my R+D unit with me next time we meet up
    Quote Originally Posted by torva_lupus View Post
    Hi guys,
    Well it took 4 or 5 hours. Don't know exactly but it was quick.
    Quote Originally Posted by the_guy_with_no_name View Post
    Hi Saab,
    tgwnn
    Well thank you guy_who_actually_does_have_a_name I can't wait till you get your light done. That will be one incredible piece of work.
    Quote Originally Posted by enomosiki View Post
    Wait...
    Woe is me.
    Sorry. I have to confess I tried to time the release where more in the US would have a shot for the simple fact that all the foreign orders will cost me significantly more to ship than my website charged. I want these lights insured due to the high value and USPS makes you bump up to a higher priced shipping method just to even be able to add insurance. The thing is I could'nt figure out how to configure that on my site to account for this so I just hoped that more US people would get them. In the end though 9 of them turned out to be foreign.
    Quote Originally Posted by Craig K View Post
    No. These were too much work. Did it just to celebrate and see off the edc line.
    Quote Originally Posted by saabluster View Post
    saab are you going to be making anymore lights in the future like maybe a new full size DEFT or something like that?
    anyone has any idea where I can find a decent case for DEFT edc?
    Mar 2011
    Champlain Valley
    Saab,
    Gimme a shout, or just ask in the reply I have not gotton yet, about international shipping and GoDaddy.
    Wow that is amazing, only two units in the US, and they both are in the North East.
    GL
    Flashaholic fishhead's Avatar
    SoCal
    Quote Originally Posted by Got Lumens? View Post
    Saab,
    GL
    But I ordered one too.....and California hasn't fallen into the ocean yet...
    Default
    Thank you Michael for all the hard work!
    I can't wait to start using this on my boat in Tennessee, though after seeing photos of how much labor of love you put into these lights, I might just have to keep this in my office and use my edc LR+ for evening and night boat outings.
    That is the plan yes. To do it right takes a lot of money and I will have to save up the funds to do it. Believe me there is nothing I'd rather do than to get that light back.
    Saab,
    GL
    I was just going off what my wife mentioned. Or shall I say what I remember her saying. I went back and checked and it was nowhere near what I thought. Only four lights are going abroad. I think.
    Quote Originally Posted by onthelake View Post
    Yeah I feel a little conflicted about that. I have always wanted my lights to be used in the field as they were intended to be. Never been much of a shelf queen kind of guy. That said I really want to see these lights taken care of. So much work.
    And now for the beamshots. I just decided to compare it to the LR+(later version with higher performance) so those with that would be able to see how they compare.
    LR+ 501'/152meters
    Enthusiast 501'/152meters
    LR+ 501'/152meters zoomed in
    Enthusiast 501'/152meters zoomed in
    Just for kicks the same shot as the one above but this is the Sipik SK68 on max throw 501'/152meters zoomed in
    LR+ 826'/252meters zoomed in
    Enthusiast 826'/252meters zoomed in
    There appear to be a lot of artifacts from the resizing as it is not quite as sharp or bright as the untouched photos are on my computer.
    Mar 2011
    Champlain Valley
    Saab,
    Thank You for the reply and clarification on the shipping .
    Those beam shots are very nice.
    I will try to due the light it's justice with beam shots like yours.
    Take Care
    GL
    Flashaholic* bigchelis's Avatar
    Oct 2008
    San Jose,CA
    wow, congrats!!!
    Now where in the world did you get those AR coated Aspherics
    Keep up the great work
    Surefire 6P with Malkoff M60 simple, bright, efficient.
    Saab, I was able to get one here in so. Calif. But I am still waiting for information to make payment on it. I used the contact page on your website. I also used the print and call option but saw no number listed there, but I did receive an automated invoice also with no contact info. Let me know. Thanks again I also have the Deft enthusiast, Amazing Light!
    Hey Saab any update on when the lights are being shipped?
    Default
    Quote Originally Posted by 51mY
    I received an email from Michael the other day and he is running a bit behind but hopes to get them out this week. Have patience, Grasshopper.
    You are getting one of the twelve lights that will ever go into production. You can't rush a masterpiece like that.
    Hi, has anyone already received the DEFT EDC Enthusiast?
    Default
    I just got my shipping notice! Thank you Saabluster! Completely stoked and can't wait to see what is coming down the road from you.
    -OnTheLake
    Seven lights have been shipped. Working hard to get the others out. It was hard packing these lights up. It feels like I'm sending my kids off.
    Mar 2011
    Champlain Valley
    Thank You SaaB.
    I have witnessed one hell of a show. I am so glad you made these last memorabilia lights. I am proud to have gotten off my kiester and actually participated. I will take care of your EDC Enthusiast. I will use it regularly and treat it with the respect you have so finely crafted into it. I wish you and the family my best. I will post a few more comments upon arrival .
    GL
    One thing I forgot to tell you all. I will not be shipping these lights with diffusers. Why? Because they don't need them. The lenses used in this light are of such good quality that defocused they have an almost perfect appearance. Very low dispersion. Very clean and clear beam when defocused. Simply unscrew the head slightly. I think you guys will be amazed
