Fenix LD41 is a high-performance outdoor flashlight with a wide range of applications. It employs the unique dual tail cap switches to provide quick switching between four brightness levels and two flashing modes – and a momentary-on function. The elongated all-metal housing, containing four readily-available AA batteries with sufficient power, makes it comfortable to hold. Featuring constant brightness and waterproofing to IPX-8 standards, LD41 can be a good partner in various outdoor conditions and in emergencies.
Technical Parameters(ANSI/FSC)
Output: 5lm (160h), 80lm (20h), 190lm (7h30m), 520lm(2h10m)
DISTANCE:200m
Intensity:10000cd
impact resistant:1m
waterproof:IPX-8 underwater 2m
accessories: holster, lanyard and spare o-ring
◎ Uses Cree XM-L (U2) LED with a lifespan of 50,000 hours
◎ Uses four 1.5V AA (Ni-MH, Alkaline ) batteries
◎ 175mm (Length) x 40mm (Diameter)
◎ 180-gram weight (excluding batteries)
◎ Digitally regulated output maintains constant brightness
◎ Reverse polarity protection guards against improper battery installation
◎ Low-voltage reminder indicates when battery replacement is needed
◎ Anti-roll, slip-resistant body design
◎ Tactical tail cap switch with momentary-on function
◎ Tail mode switch, one click for brightness selection
◎ Made of durable aircraft-grade aluminum
◎ Premium Type III hard-anodized anti-abrasive finish
◎ Toughened ultra-clear glass lens with anti-reflective coating
more detail:http://www.fenixlight.com/viewnproduct.asp?id=115
