ArmyTek
Results 1 to 10 of 10
Thread: A REALLY long term (11 year) review: Brinkmann Long Life LED Light
    Flashaholic* zespectre's Avatar
    May 2005
    Shenandoah Valley
    Default A REALLY long term (11 year) review: Brinkmann Long Life LED Light
    I was out in my storage shed today and needed light, so I grabbed the flashlight I keep out there off the shelf and clicked it on. Kinda dim, but it worked and sufficed for the job at hand. Then I looked at what I had in my hands and it really made me pause because the light I've left in the shed all these years was my VERY FIRST LED LIGHT!
    The Brinkmann Long Life
    This light, with it's 30+ hour battery life and "bulb" that would never burn out was a completely new idea to mainstream lighting when it came out around 2001. To look at it now we'd laugh. It's plastic body seems fragile (though it has obviously held up), it's switch is large and clunky, and don't even get me started on the pathetic light output, sickening blue color, and silly collimator lens.
    Yet here it is, still serving a purpose and working even though it gets left in an unheated shed.
    Oh and as far as I can remember, this is only the third set of batteries I ever put in the thing (I only just put new batteries in it because I noted the the expire date on the batteries)!
    "Notorious collector of things that glow, shine, or blink"
    CPF # 9435
    Default Re: A REALLY long term (11 year) review: Brinkmann Long Life LED Light
    Great story! Thanks for sharing. I hope to do some tribute threads in the future and this gives me inspiration (although my first LED light only dates back to 2008).
    Cheers,
    Tim
    Flashaholic* HighlanderNorth's Avatar
    Sep 2011
    Mid Atlantic USA
    Quote Originally Posted by zespectre View Post
    I'm so tired of people posting reviews of lights that they've only owned for 11 years or so! I mean, you've got to own a light for at least 35 years before you can possibly have a good idea of whether its good or not.
    Just kidding!
    Some days you are the bug, some days you are the windshield.
    Flashaholic* madecov's Avatar
    Feb 2003
    Houston, Texas
    I'm not sure I have anything around here that is 11 years old.
    I keep upgrading stuff.
    In god we trust.........all others are suspects
    There are no problems in life that can not be solved with high explosives or small arms
    Too many new lights to list
    May 2005
    Shenandoah Valley
    Quote Originally Posted by madecov View Post
    Oh believe me, I upgrade stuff all the time. That is part of the reason I was so astounded to realize that I still use this light. My only other long-term light is a 20 year old magcharger but that doesn't strictly count since it has a different battery pack, upgraded bulb, and aftermarket "light orange peel" reflector.
    CPF # 9435
    Dec 2007
    California Republic
    The better bit of info there is that the light has survived years of hot/cold/humidity in an outdoor storage shed; quite a testament to the longevity of the LED that even in an old, cheap configuration, it survives without issue.
    Also, if those are Energizer Lithiums you're using (which you should in a semi-outdoor application,) ignore the expiration date; they won't leak or swell if worn down to zero like alkalines.
    Flashaholic* Sean's Avatar
    Dec 2001
    IL, near St. Louis MO
    Default
    I remember that light! Good to know it still works.
    Interesting story..
    May 2005
    Shenandoah Valley
    Default EVEN LONGER long term review (16 years and counting): Brinkmann Long Life LED Light
    16 years and this light still gives reliable service in my storage building which has no internal lighting.
    The building has no insulation, gets damp, is dusty and messy and gets hot in the summer and cold in the winter.
    And still the light, which sits on a shelf right by the door with Lithium AA batteries in it (it's only on it's second set of those) works every time.
    Oh come ON... it's made of cheap plastic with wimpy "O" rings and a thick, chunky, Ka-Chunk Ka-Chunk type of switch. How can this thing POSSIBLY still work?!? LOL.
    But it does.
    Amazing.
    CPF # 9435
    Default Re: EVEN LONGER long term review (16 years and counting): Brinkmann Long Life LED L
    Amazing!! Very cool story... and to update 5 years later no doubt.
    Last year I found a cheap little buck 99 WalMart brand "Ever Active" in the door of my 95 pickup truck I put there in like 98/99. It still had the Ever Active batteries in it, but they had long since depleted. No leaks!!! Fresh cells and it worked fine.
    But my first LED was a bedside light made by LED Lenser. It put out an amazing 12 lumens from 3 emitters run off 3 N cells. Last summer one of the cells began to leak so I retired it. The little plastic WalMart light also got retired. They are both on display now.
    John 3:16
