Hi George. I never intended to run any of these packs down past where I could see that a bad/under performing cell did in fact exist. The one time that I did see a second cell crap out, it happened almost immediately after the first, and again, this was accidentally. I did not want to damage the packs anymore than necessary, just far enough to determine if indeed there was a bad cell.
I can't answer that question. Tom (SilverFox) suggested I monitor individual cells in the pack while discharging on the CBA II. The problem was that these packs are shrink wrapped and I would have had to puncture through and measure each cell with a needle, or something to take measurements. Since these packs are welded cells, I really could not replace the bad cells anyway, and as they still worked and ran about $60-$70 a pack, I didn't bother potentialy damaging the wrap, to find out. I have no doubt that at least sometimes, the weak cells were reverse charged. It would be almost impossible, considering the 10A+ load put on these diminutive cells.
These packs still work, just not nearly as long as a new pack. The 14.4 Volt pack should run the M@g for about 9 minutes, and the 15.6 Volt pack for about 7 minutes. The 14.4V pack will only go for about 2 minutes or less, last I checked. The 15.6V pack fares a bit better and will go for about 5 minutes. Actually these are cumulative runtimes. At 140-170 Watts, the "2D" M@g gets way too hot after about one minute and needs a "rest".
Anyway, both packs have bad cells in them, but still work. No one makes packs for them anymore, either. This light isn't really all that useful anyway, although it is quite capable of illuminating a large pasture etc. and has been used for such. I have a FiveMega "2D" 12 x 2/3A cell holder (the light body is "tri bored"), that I've never used. When these packs finally die, I'll just use it, albeit it will only give me the lower 14.4 Volt output. Good 10A+ capable cells are hard to find also, adding to the problem.
Dave
