Hello all! I'm looking for a tough, fairly high-output rechargable flashlight for my worktruck/trail rig/tow rig/firewood hauler. It needs to be heavy-duty, highly water, mud, and dust resistant, rechargeable, and fairly powerful with a reasonable run time that can take being knocked around. Durability and reliability are paramount but I'd also like some decent light out of it (considerably more than my reliable but sort of anemic 3D Mags). I know, I'm not asking much... Here's my checklist:
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
____I will be mail-ordering or buying online, so this doesn't matter.
_X__Don't care
2) Budget: An easy question, but you may change your mind after answering the rest!
____Less than $25.
____Less than $50.
____Less than $100.
_X__Less than $150.
____Less than $300.
____I have no limit.
_X__I'm flexible, tell me what you got.
____Other, please specify ________
3) Format:
_X__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
____Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel case.
_X__I don't care.
____I don't know.
____N/A
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
_X__I don't know (though LED would probably be best due to efficiency, longevity, and shock resistance).
6) Manufacturer:
_X__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
_X__I would consider getting a light that is pieced together (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today's most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
_X__As long as they're rechargable (I guess I don't really know enough about it to strongly prefer one over another)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
_X__I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_X__5-20 yards/meters (check out a noise in the backyard)
_X__30-50 yards/meters (I have a big backyard)
_X__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
_X__150+ yards (I want maximum throw possible)
_X__(I'd really like a variable beam such as what Maglites have. I know they're beams aren't the best or cleanest [by a long shot], but they are versatile)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
_X__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_X__Very Important (Camping, Backpacking, Car Glove-box).
_X__Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don't know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
_X__I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
_X__I don't care but I need reliability and like simplicity.
____I don't know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
_X__I don't care as long as it's tough and well built.
____I don't know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
_X__Other:__a secure charger/mount that can be screwed to the floor of my pickup. I like the simple MagCharger design that has no wires to unhook/rip loose, no plugs/recepticles to get plugged with dust and mud, and that works regardless of light orientation. This is a big deal to me and may end up being the deciding feature.
As you might have guessed by reading this, so far I'm leaning toward the MagCharger. I've owned a lot of Maglites in the past and, though they certainly do leave something to be desired in terms of output, and power-to-weight, they are simple, durable, well built, and resistant to the elements (at least in my limited experience; I'm no flashlight expert). Supposedly the MC is considerably more potent than the standard 3D Maglite I'm used to carrying? Also, I'm not at all against some simple mods so long as they don't affect durability/reliability or drastically reduce run time to an unuseful level.
All that said, I'm open to anything, but the MC is the only rechargable I could find that has the output and rubustness I'm looking for with a holder/cradle type charger. But like I said, I'm open to anything if it fits the bill.
I guess the main thing holding me back from just getting the MC is my own inexperience with high-perf. flashlights (I have no real idea how bright 10 or 100 or 1000 lumens is, etc...). I have read a dozen different specs and opinions on the MC in my searching, and I'm thoroughly confused.
I am also somewhat concerned with the new electronic switch they're now evidently using. I'm not sure I like the idea of having to click through several choices of lighting to get the thing on or off, and I have real concerns about the reliability of an electronic switch. Also, can a new MC still be modified or will the new switch limit modifications or ultimate output?
I've been researching this on and off all weekend (yeah, I get fixated sometimes... ), but for every question I answer I find two more to ask. So what do you folks say; is the MC my only real choice or are there alternatives I have overlooked? Will the new style MC with the electronic switch still lend itself to modification like the old one and prove equally reliable? Thanks, and you have a very interesting site here.
_X__Don't care
____Less than $25.
____Less than $50.
____Less than $100.
_X__Less than $150.
____Less than $300.
3) Format:
____Keychain size.
____Holster carry.
_X__I don't care.
____I don't know.
____N/A
6) Manufacturer:
____I don't care.
____I don't know.
_X__I don't care.
____I don't know.
____I don't know.
____I don't know.
____Holster
