Olight New Models!
Results 1 to 3 of 3
Thread: Lizard / Plants lighting
    Help Lizard / Plants lighting
    Hi everyone,
    I'm trying to build a light for my terrarium (like aquarium, just for reptiles :P ).
    The specs are:
    I need about 2500-3000 lumen output (for the plants to grow properly), of natural light + some red light, led of choice: nichia 219, so I figured I'll need about 12 nichia's, perhaps 4 tripple stars and 3 red xr-es?
    Max flood, as this thing should cover a very close surface (20" or so) but I dont want too much light 'escaping' through the glass walls, is there anything I can do?
    About the input - I live in Israel so its a 220 socket, anything special I should know? Could you point me to specific drivers and adapters I'll need?
    About temp managment - All of the leds will be mounted on an aluminium rail with some cooling fins. if that wont be enoguh I can add some active cooling as well.
    Another thing, I have no experience at building fixed lights, so any guides/tips will be more than great!
    Thanks!
    Edit: the tank size is 24/17/17" approx (h/w/l)
    Default Re: Lizard / Plants lighting
    There are quite a few threads about building aquarium lighting on CPF that should be of help to you...one question though, will you still be using a "reptile light bulb" to provide the IR and UV the lizards need? Or were you planing to try LEDs for that as well?
    Quote Originally Posted by mahoney View Post
    The type of lizards I have doesnt require UV/IR light so I dont think so, unless theres a hidden value for the plants (?).
