Orbita
Results 1 to 6 of 6
Thread: Fenix e01 & chap stick: great survival kit addition(multi uses)
    Flashaholic* 4x4Dragon's Avatar
    Nov 2002
    Lexington, SC
    Default Fenix e01 & chap stick: great survival kit addition(multi uses)
    So most of us all know the lamp/lantern trick with the cap but just today I discovered some other uses for the chap stick. I was cleaning up my e01 and added pocket clip (from maratac AAA) and soon discovered that the on/off twisting action was a bit rough. Yep, oring was dried out. So I took the chap stick and lubed up the oring..... back nice and smooth! Then it immediately struck me, I could also use the chapstick as a fire starter, perhaps with the addition a cotton ball ball or two. The combo has found a permanent place in my backpacking gear especially now that the pocket clip will allow me to also use the e01 as my headlamp attached to the brim of my hat.
    EDC: JetBeam C-LE v2.0(in transit)----Fenix E01
    Default Re: Fenix e01 & chap stick: great survival kit addition(multi uses)
    I couldn't agree more! I have several twisty lights and I always lube up the threads\o-ring with my chap stick. It works really well and it's super handy. The two things that I always, ALWAYS have on my person are chap stick and a light so it's perfect. I haven't tried the fire starter application yet but now I'm definitely looking forward to it!
    Spread the word!
    Dec 2009
    USA
    Thanks for the info! I never would have realized that Chap stick was so handy.
    I read your thread a couple days ago and then today I was out at a customers house for a water leak. The shower valve was bad, so I went and bought a replacement. During the install, I got to step 4...lubricate the orings...DOH! I forgot to get the silicone lube! But, I had chapstick and ten minutes later, no leaks either.
    Thanks for the thread!
    Maglite xl50...Fenix E05...Nebo Redline SE...Maratac AAA...Thrunite Ti firefly...Quark x AA^2...Maratac CU Rev1...Maratac CU Rev2...Fenix LD01SS...Solarforce L2T
    Flashaholic* srfreddy's Avatar
    Sep 2010
    New England
    It could be dangerous to use petroleum lubricants on some orings, as they could break down. It depends what they are made of.
    Nana Re: Fenix e01 & chap stick: great survival kit addition(multi uses)
    both Lithium Grease and silicone grease are available for o-ring on Fenix flashilight.
