ThruNite
Results 1 to 10 of 10
Thread: 2D to 3C Maglite question
    Default 2D to 3C Maglite question
    I'm getting a 3-4D XM-L 700 Lumen Malkoff Drop-in, but I want to use it with my 2D Mag with 3C cells, alkaline for awhile...until I can afford 3C NiMH's and a charger-
    Will my output be 700 Lumens or close to it?
    Does the switch need to be modified?
    Is it just simply cutting some PVC, modding the spring, and adding 3 C cells, or am I missing something that is very obvious to the more informed?
    Thanks-
    Flashaholic* JamisonM's Avatar
    Apr 2006
    South Carolina
    Default Re: 2D to 3C Maglite question
    I highly doubt you'll get 700lm. Using 3C in a 2D maglite only requires you cut a piece of 1" PVC to length and modifying the spring. Pretty simple. Here's the tailcap from one of my 3D maglites. I've also seen others where the spring was turn upside down and even cut down and recessed in the bottom of the tailcap after the anodizing had been removed.
    The Runtime Index | For the disparate, my DIY Pocket Clips
    JamisonM-
    Cool, thank-you...
    How many lumens do you think it will output?
    +1 for what Jamison said.
    The mod is simple. You dont have to work on the switch unless you just want to lower the resistance for slightly higher output. Alkaline cells are really just not up to the task of powering an LED like this. On 3 C alks at the 1 second mark it will be high, but by about the 30 second mark your going to be looking at around 400 ish lumens is my guess.
    The only XML mags I ever sold that the buyer had strict intentions of running on alks were a 4 and 6 D cell. Even 3 D cell alks would only power it to about 2-2.3A if I recall right.
    This is just my opinion but when you do get your NIMH cells I suggest saving a few extra dollars to get a good set. It makes a difference. My personal favorite are the Accupower LSD C cells. I have driven lights to 13+ amps on 3 of these. They carry a load well, and they are always charged when you come back to them. About the only draw back is you have to buy them in a 2 pack.
    Good luck.
    In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
    Shorty C/D M*glites
    Thanks
    +1 Accupower LSD's
    IF you have not ordered yet I would go for the 6 cell drop in, tail cap mod and 2x 26650 or 2x32650
    Oct 2007
    Sitting' on the dock o' The Bay...
    How are ou attaching the thinner C-cell drop-in in the wider D-cell host?
    Quote Originally Posted by CMAG View Post
    That is an idea....but Gene doesn't have a 700 lumen 6 cell drop-in (yet)-
    Quote Originally Posted by PCC View Post
    I'm using a 3-4D cell drop-in in a 2D Maglite with 3 alkaline or NiMH C cells-
    Flashaholic ssvqwnp's Avatar
    Oct 2010
    Louisiana
    Quote Originally Posted by aL01 View Post
    snip
    /snip
    It seems I was too slow...
