Hi all.
I have a lighting fixture that includes 6 LEDs in couples
they are aranged in a nice plastic base and look like this:
this unit can easly be connected or disconnected from two wires, you can see how is is done from its opposite side (I've removed the board from its plastic base):
after using them for about a month, one led is flashing and the others are not working.
I need help with fixing those units because I cant find replacements here. I found them online but only in USA and no-one will send them over.
on the board itself I can see written next to the LEDs: "JD1W LED". So I assume they are 1w :-)
I dont know where can I get these kind of small LEDs. coulnd'nt find searching ebay. any help with that would be appreciated.
I have a soldering iron and some tin.
I also can get my hands on a volt/amper meter from work. I don't know why the leds stoped working, I believe that maybe the volt supplied by the lighting fixture is too large and there are no sufficiant resistors.
please tell me what to do and how can I replace the LEDs and fix them so they wont be ruine again.
here is a side view and a front view without the plastic base:
thanks in advance and I hope someone will be able to help.
