aliendogstar
- Joined
- Jul 8, 2012
- Messages
- 5
Hello, I was doing some research on flashlights and followed a google search which led me to the CandlePowerForums. I have been reading some threads for further research. I am looking for an every day carry handheld flash light that I can fit inside of a small leather bag that I carry my Spyderco Cricket knife, car keys, debit card, id, and firesteel in. The inside dimensions of the bag are 4 inches wide and 3 1/2 inches high. I like to carry all of my things in one bag as it makes it easier to keep up with everything rather than have stuff in each pocket. I want a light that will fit into the Fenix Flashlight headband as I am thinking of purchasing the Fenix headband so that I can use the light as a headlamp while I am hiking or busy working with my hands in a situation where my hands aren't free to hold the light. I would like a light that has plenty of flood or spill for illumination a wider amount of space at one time. Distance would be nice but I understand that there isn't one flashlight that will do everything. I do understand that one light may excel at distance but not be suitable for close range situations or vice versa. I would like something that has a high and a low setting or multiple settings. I was looking at the Quark 124 R5 Edition which I like the size of. And it seems like it would fit into the Fenix headband as well. The Fenix headband will accept lights between 18mm and 22mm. There may be other manufacturers that make headbands that would fit this style of light, but I haven't really searched as the Fenix was just the first one that I saw so I may go with that one unless someone else can recommend a better one. I will be using this light as a general all around purpose light. I already have a Surefire P2x which is fine for larger task where I need a big light with a lot of lumens. I am wanting something small to carry on my person at all times. Thank you in advance for any suggestions or help that you may be able to offer regarding this post.
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
__X__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
____Less than $25.
____Less than $50.
__X__Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
____I'm flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
__X__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
_X___Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don't care.
____I don't know.
____N/A
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__X__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today's most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
__X__I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
__X__I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
__X__I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
__X__I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
__X__Less than 1 yard/meter (reading, other close work)
__X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
__X__30-50 yards/meters (I have a big backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__X__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don't know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
__X__I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
__X__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
__X__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don't care.
____I don't know.
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
____Less than $25.
____Less than $50.
____Less than $150.
____Less than $300.
3) Format:
____Keychain size.
____Holster carry.
____I don't care.
____I don't know.
____N/A
____I don't know.
6) Manufacturer:
____I don't care.
____I don't know.
__X__I don't care.
____I don't know.
____I don't care.
____I don't know.
____I don't care.
____I don't know.
____Holster
