No, SMD strips are not better than going DIY. Some of you are just afraid of a soldering iron.
There are excellent SMD strips out there populated with Osram, Phillips, and Cree LEDs, but by and large the majority are trash made from no-name Asian factories. 'Neutral-white' in this case may by 2700K, or 8000K, and the color is usually terrible. If you can find SMD strips at a local big box store with good color and out-put, then go for it. I can't find decent ones that don't cost a fortune for 12" lengths.
If you didn't need dimming I'd advise something like a Mean Well LPC-20-350 (or equivelant) which costs a whopping $12 at Jameco. The LPC-20-350 can drive 4-14 Rebel ES's or Cree XP-Gs or XT-Es in series at 350mA and all it needs is a plug to go into your wall outlet.
For dimming, usually DC/DC drivers are cheaper and more convenient for small builds. Either use the gear AnAppleSnail advised, or if you want spend a bit more money on a LuxDrive wired buck with built on dimming. These cost around $15.00, and have pot you can turn to get full range dimming. Feed it 12volts if you want to use three LEDs listed above, or more voltage if you want to use more. Spare laptop bricks usually work very well for this.
