Foxfury Scout
Results 1 to 14 of 14
Thread: SOLD: Dafabricata P7 modded Gray KL4 Head only (stock board) *2nd price drop*
    Default SOLD: Dafabricata P7 modded Gray KL4 Head only (stock board) *2nd price drop*
    This is the exact head as seen here:
    http://www.candlepowerforums.com/vb/...Rare-body-left
    It's in the same condition as above. Runs on 2 primaries or 1 li-ion. It puts a stock KL4 to shame
    SOLD Asking $95 $90 $85 shipped SOLD & Shipped!
    USPS Priority w/ DC CONUS Only
    Flashaholic* archimedes's Avatar
    Mar 2011
    CONUS, arteriosus
    Default
    Any idea of the current draw, or approximate lumen output ?
    Also, just one level, correct ?
    Direct drive, or regulated ?
    IF 2 = 1 THEN 1 = 0
    Default Re: WTS: Dafabricata P7 modded Gray KL4 Head only (stock board)
    Hi archimedes!
    Not too sure, I did a lot of research and couldn't really find much info on it.
    Anyhow, yes, it's one level - not too sure if it's DD or Regulated. It uses the stock board, but I'm not sure if that has anything to do with it being DD or Regulated.
    edit: Some sources say about 600 lumens
    Mar 2011
    CONUS, arteriosus
    Default
    Hmmm ... tempting
    Anything you could compare it to, in terms of informal "ceiling bounce test" for output?
    Maybe something standardized ... perhaps a SureFire, HDS, Malkoff, etc.
    Also, how's the tint? And is there a "P7 donut hole" in the center of the beam?
    Thanks for the info !
    IF 2 = 1 THEN 1 = 0
    Quote Originally Posted by archimedes View Post
    Hmmm ... tempting
    It definitely lights up an entire room, that's for sure. In terms of tint, I have a Milky Expurgator with an XPG-R51C and the XPG is slightly cooler than the P7. The P7 has an ever so slight neutral tinge to it (at least to me). As for the donut hole, it's not too noticeable. I was going to stick some diffusing film over the lens, but later on I decided it was something I could live with.
    PM sent & Price Drop!
    Mar 2011
    CONUS, arteriosus
    Default
    Quote Originally Posted by samuraishot View Post
    ....Asking $95 $90 $85 shipped
    I wish I could resist, but at $85, I'll have to say ... I'll take it
    Please PM with PayPal info - thanks!
    IF 2 = 1 THEN 1 = 0
    Default Re: WTS: Dafabricata P7 modded Gray KL4 Head only (stock board) *2nd price drop*
    I'm glad it's going to you, archimedes PM on the way with PayPal info!
    The stock driver is a boost driver that ran a Luxeon V LED, whose Vf was around 6V.
    A Seoul P7 Vf at 3A drive is around 3.5V.
    I would run this light only with 1xLi-ion (e.g., a 17670). You will be in direct drive
    since Vbatt>Vf, and most likely the P7 will be pushed hard. I definitely would not
    use 2xIMR16340, which would probably fry the LED and/or driver. I also would
    not use 2x123A because the current draw would be excessive for those cells.
    Mar 2011
    CONUS, arteriosus
    ... pleased to be doing business with you again
    Quote Originally Posted by Justin Case View Post
    Yep, this is what I was thinking ....
    IF 2 = 1 THEN 1 = 0
    Got it, it'll be out tomorrow!
    Mar 2011
    CONUS, arteriosus
    Just arrived .... Yep, it's BRIGHT!
    Thanks for the quick ship, and the little "extra"
    IF 2 = 1 THEN 1 = 0
    Default
    No problem, I'm glad it arrived safely! I kinda miss it now haha
    Enjoy!
