Looking for 2xCR123 (2xRCR123) headlamp
Liviu
I am looking for a high performance 2xCR123, more specifically 2xRCR123, headlamp, with long running time, and reasonable light power.
Any suggestions?
Liviu
I want more flood. Do you now if there is any possibility to use both rechargeable and normal CR123 in Princeton Tec Apex Pro?
I am asking specifically about 2xRCR123 since I have an USB charger for this type of rechargeable batteries.
Any other suggestions besides Princeton Tec? Or any other battery configuration based on the above headlamp features?
skyfire
Los Angeles
diffusing a beam for more flood is pretty easy.
spark also makes a few models such as the SD6 and ST6, that can use 2xCR123, or a single 18650 li-ion. i dont know if it takes 2xRCR123 though.
ive never tried a spark light myself, so i cant comment much on it.
peterharvey73
Yes, just the Spark SD6 and ST6.
The SD6 is pure flood, with no reflector, or an optional small reflector for only $10.
The ST6 has a bigger reflector for more throw.
However, both only output 500 lumens.
Like Skyfire says, it will take 2xCR123's @ 2x3.0 volts, but I'm not sure if it will take 2x16340's @ 2x3.6 volts, because the working voltage range for these lights is from 1.6 volts to 6.8 volts.
On the otherhand, the Zebralight H600 weighs a lighter 39 grams on the head, yet also outputs 750 lumens, but it requires an 18650; it will not accept 2x CR123, let alone 2x 16340's.
An 18650 charger like an Ultrafire charger is only US$15...
Zebralight H600 18650 XM-L 750 lumens OTF @ 80 degrees spill beam and 12 degrees hot spot.
