NEXTORCH
Results 1 to 22 of 22
Thread: 1xAA Light recommendations
    Default 1xAA Light recommendations
    I have a Fenix PD30 and a foursevens preon 1.
    I am looking for a light smack dab in the middle. One AA cell, light output in the low 100ish range, sized in the middle of the two. Must have a good pocket clip.
    Any ideas?
    Flashaholic* TweakMDS's Avatar
    Jun 2012
    The Netherlands
    Default Re: 1xAA Light recommendations
    I'm gonna recommend you the EagleTac D25A Clicky, and Titanium versions are still available ^^.
    Some pics and review here: http://www.everydaycommentary.com/20...ml-review.html
    Jan 2010
    Melbourne, Australia
    The EagleTac D25A is a great little light, but I will have to go with the Sunwayman V10A or the Zebralight SC51. These are great little single AA lights, especially the V10A.
    Flashlight Selection Process: Pick any two, and only two of the following: Bright, Cheap, Long-Runtime.
    Jun 2012
    The Netherlands
    I don't want to derail, but just wondering and might be useful to OP: is there any advantage of the V10A over the V11R (w/ AA extender)? I'm also looking at both, but it looks a bit clunkier to EDC.
    Default
    Well, the PD30's diameter is 21.5mm
    I was hoping for a slimmer light, that would be thicker than the preon.
    The D25a comes in at 17.5mm
    V10a is 23mm
    SC51 is 22mm
    Looks like the eagletac is in the ballpark. Thanks for the suggestions so far.
    Default
    I'd also consider the Quark AA2X on an optional 1xAA tube. Full Li-ion support and the spare tube also makes a great extra batt container. I really wanted to get the D25A clicky, but the mode spacing seemed off - kinda wide at the low end and narrow at the high end considering 4x lumens = 2x perceived brightness.
    Just my 0.02
    Default
    The quark is just too thick, or I'd probably be going with that. Thanks though.
    Flashaholic Danielight's Avatar
    Dec 2011
    OH
    Arrow Re: 1xAA Light recommendations
    Did you have a particular dollar figure in mind? I personally like my Sunwayman V10A, but have also bought budget lights from the Shining Beam website. You should check out the selection of AA lights there.
    ὁ θεὸς φῶς ἐστιν
    May 2009
    Mid to SoCal
    I'm very happy with my Fenix E11, and it's nice and small for a single AA light. It has a forward clicky and runs two modes (105 lumen and 32 lumen with bezel loose/tight). It does not come with a pocket clip, and if it did it would be headed toward perfect for the size. If anyone can figure out where one might obtain a pocket clip that would fit, the E11 might work out very well for you. It's also very reasonably priced at less than $30
    Two of my single AA lights with decent clips are the Jetbeam BA10 and Olight i2.
    Both reasonably priced, the Jetbeam is brighter and larger of the two. May be larger than you are looking for though.
    In my opinion the Jetbeam is far better than the Olight, nicer finished and tough as anything. But the olight is good value and pretty small with a strong clip. My i2 mode skips a bit which bugs me sometimes.
    Enlightened dmkatz76's Avatar
    Aug 2011
    Illinois
    Another vote for the Eagletac D25A clicky.
    I really like my Foursevens Quark AA (I think it's called the Quark Pro QPA now)...
    I think it pretty much meets all your requirements. 109 Lumens, single AA cell, good pocket clip.
    I also like that the pocket clip is reversible so it can clip on to your cap.
    Default
    Quote Originally Posted by jonathanhong View Post
    The quark light is too thick.
    The eagletac is the only one so far to hit everything on my list.
    Flashaholic* climberkid's Avatar
    Jan 2008
    Goldsboro, NC
    Default
    Olight T15. On sale at battery junction. 115 lumens, 3 mode.
    Light, 4 primary AAs, shipping. All for under 30 with CPF coupon code.
    -Alex
    -Alex
    Default
    Quote Originally Posted by climberkid View Post
    -Alex
    21.6mm diameter and no pocket clip. Are you even paying attention?
    Jan 2008
    Goldsboro, NC
    Default
    Quote Originally Posted by JonnyRocket View Post
    You said hoping for slimmer, not requiring. Now I know.
    Forgot about the pocket clip deal.
    -Alex
    -Alex
    Default
    -Alex
    No problem
    Sorry if I came across rudely, I was having a bad night.
    Jan 2008
    Goldsboro, NC
    Default
    No problem
    You're fine Jonny. I assumed so, glad I refrained from a smart ass remark. lol
    Looks like according to every single AA thread, the EagleTac is your absolute best choice. Away from customs of course.
    -Alex
    -Alex
    Default
    -Alex
    I'm considering picking up a new light. What is the CPF coupon code and the corresponding discount?
    Thanks
    Apr 2012
    Australia
    Quote Originally Posted by mikeand View Post
    Thanks
    I have the olight AAA i3. For $20, the AA i2 looks very good. But I've only ever owned Olights so can't compare to the eagletac.
    http://store.advancedmart.com/ghiial12ulbr.html
    I've had one as my backup EDC for more than a decade.
    My only caution is that it can twist on and run down the battery, so I put an o-ring between the tail-cap and the battery that I remove when I need it (once a year.)
    *Flashaholic* Gunner12's Avatar
    Dec 2006
    Bay Area, CA
    The Zebralight SC51 could work well. Bright for a 1 AA light, small, and has a good clip too. Also comes in Neutral and warm white.
    If you don't need a clickie, a 4sevens Quark Mini is pretty small.
