railgun_livewire
- Joined
- Jul 17, 2012
- Messages
- 6
Hi all, thanks for your time!
I'm after a new flash light and don't really want to get carried away with new battery formats...
Hopefully the survey below helps!
__x__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
____Less than $60.
3) Format:
__x__I want a flashlight
4) Flashlight-specific format/size:
____I don't care.
5) Emitter/Light source:
__x__LED (what's HID?)
6) Manufacturer:
__x__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
____I intend to use standard size batteries (AAA, AA, C, D) nimh or lithiun
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
__x__I want as much as I can get
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
__x__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____90-120 minutes (Runtime is moderately important, but still not critical)
____Fairly Important (It's not going to be used as a weapon, but I won't drop it either).
12) Switch Type and location (choose all that apply):
____I don't care.
____I don't care.
14)Material/Finish/Coating
____I don't care.
____Less than $60.
3) Format:
____I don't care.
6) Manufacturer:
____I don't care.
____I don't care.
____I don't care.
