jackknifeh
- Joined
- Aug 27, 2011
- Messages
- 36
My Fenix LD01 has 3 brightnesses. When I twist the head it starts at med. all the time, then cycles to low then high. Luckily this works just fine for me. Other lights remember the setting they were set to when turned off and when they are turned on they use the last setting. This sounds convenient thinking the last one you used is your most used. That will not always be the case. If I wanted to turn my light on in the middle of the night in the bedroom I don't want to wake wife. If I last used the light at the high setting that's the one that will brighten the entire room. My question is, is there a light where you can "set" your own first brightness? When you turn the light on it would be at your setting, not the last one or what the factory set it to.
Thanks,
Jack
Thanks,
Jack
